Question about Cooktops
Cut out dimensions for simpson gas cooktop & Simpson Harmony Nova made prior to 1999
Original owners never left the manual for Simpson Harmony Nova Oven and Gas Cooktop both are now not working, as the cooktop is situated on the bench above the oven we can't measure the cut out size that we need to purchase a new oven and cooktop. Can you help with the dimensions of the cut out pieces? Thanks Lorraine
  • 619 Answers
SOURCE: Our cooktop will not turn on!!
Plug the power line press the reset button.
Posted on Jan 05, 2008
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Krazytech
  • 725 Answers
SOURCE: Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Posted on Apr 05, 2008
reg501
  • 413 Answers
SOURCE: Ticking sound from GE cooktop igniter
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
Posted on Jun 12, 2008
  • 10865 Answers
SOURCE: new lp gas reg needed
hello Michael - I recommend that you call your propane provider. They will be able to help you.
please rate my answer. thanks
Posted on Feb 12, 2009
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Simpson EZISET cooktop control knob does not turn
    Take some electronics contact cleaner, CRC is best, and spray the knob. It has grease inside that is preventing the spring from popping it up so it turns. You'll need to get a new knob eventually and please don't install it yourself unless you are well versed in working with gas.
    May 08, 2015 | Cooktops
    Simpson fabulous 400 oven
    best to measure the the hole size and then go and see a glazier for him to cut you a new heat treated piece.
    Jan 18, 2014 | Jenn-Air Cooktops
    What are the dimensions for the JED8430??
    The top dimensions are 29 3/4" x 22" and the cut out needs to be 28 7/8" x 21 1/8" if the need the install manual you can get on the link below.
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/8101P419-60.pdf
    Good Luck and please Rate 4 thumbs for the free answer
    Jun 06, 2010 | Jenn-Air JED8430 Electric Cooktop
    I can't find my owner's manual &want to use the self clean option
    OK, here's the manual for your Jenn-Air CCE3401 cooktop in a pdf format that you can download and print, for free!
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20CCE3401B.pdf
    IF this isn't your cooktop, as that's the model number you entered on this site, requesting help, go to the following link and enter in your model number to get the correct manual for your particular Jenn Air appliance:
    http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
    Hope you find this Very Helpful and best regards!
    Aug 28, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Poor gas flow to GE cooktop
    Try a bigger inlet pipe sounds like pipe too small for load .
    Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
    Broken griddle control
    Hello
    It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Jun 28, 2008 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
    Cooktops Logo
    Top Cooktops Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Cooktop Expert? Answer questions, earn points and help others
