Question about Motorola Mobility HS801 Consumer Headset
Bluetooth Motorola Hs801 Pairing
I am having a problem with getting the blue light on bluetooth to stay on so i can pair with my phone. I have tried holding the two buttons for 3 - 10 secs, and it will not stay on, it will either be off completly or it will blink. please help
After hs801 is switched on, hold one of the volume buttons till the LED(blue) stays ON, then you can pair device to any phone. Pass code is 0000.
Posted on Nov 03, 2008
I don't know what model Motorola bluetooth headset I have but I don't know how to get it into discoverable mode to sync it to my phone.
Most Motorola headsets automatically go into pairing mode when you turn them on. If you have a light on your headset, it will be pink when you turn it on (and will begin flashing) and then change to blue. When the light is pink it is ready to pair. If you don;t have a light on your headset, it will stay in pairing mode for 10-15 seconds.
Turn your headset OFF then, (with your phone turned ON) in your phone's menu (usually) you'll go to Settings > Connectivity > Bluetooth (and select ON) Then select, Search for Bluetooth Devices and at this point you want to turn your headset ON.
It may take a couple of tries to get your phone to locate your headset but when it does it will identify the headset by the headsets model number when it locates it.
The pairing code should be four zeros. 0000.
Dec 20, 2009 | Motorola Mobility Bluetooth Hands Free...
Does not conect to cell phone What is the
First fully charge bluetooth.close bluetooth flip/turn on power by press button in the midle and open flip look blue light not flashing ok for pairing.if not do again and again,pairing only light stay on no flashing.
In phone go to bluetooth function/bluetooth turn on/searching devider ok/enter 4 zero ok.sucessful for pairing.
Jul 10, 2009 | Motorola Mobility HS850 Consumer Headset
Blue tooth is not pairing
have u tried activating your bluetooth on your mobile and press and hold the button on your headset until the light comes on it should then recognise iit
May 26, 2008 | Motorola Mobility HS801 Consumer Headset
Hs801
how can i connect hs 801 bluetooth with mobile how it become on pairing mode
May 23, 2008 | Motorola Mobility HS801 Consumer Headset
Detect & Connect Motorola HS801
HS801: Enter pairing mode by simultaneously holding down volume and Connect/disconnect key (Chrome finish key next to blinking BLUE LED.) When BLUE LED is steady, headset is in pairing mode. LG TU550: Menu key (top left button) Select SETTINGS; '5' CONNECTIVITY; '1' BLUETOOTH; '1' BLUETOOTH on/Off; '1' ON; '2' DEVICE LIST; Select NEW (Top Left hand Button) LG searches for new device/s; . Select HS801; Press OK; enter password 0000. Connection is made when HS801 BLUE LED resumes blinking.
Apr 27, 2008 | Cell Phones
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
Problem pairing
just after turn on both's blutooth. turn on blutooth search of headset also by pressing vol key for 3 sec.. then the blue light will turn on for few sec .. make search on mobile for blutooth device and u will pair it...
Nov 07, 2006 | Motorola Mobility HS801 Consumer Headset
Motorola Mobility HS801 Consumer Headset Logo
713 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
