Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
GE Unitized Spacemaker Washer and Gas Dryer
We put one sheet into a medium sized load and turned the machine on to begin the cycle. The water never stoped filling and came out of the back of the machine. It was overflowing from the machine itself, not the wall or the pipes. We had left the house and it flooded the entire apartment. I do not own but rent through a landlord so I do not know if it is under warranty. I do know it is less than 2 years old.
  • 725 Answers
It may be your pressure switch... it is what stop the water from over flowing the washer let me know if you want to change it yourself...I can help
Posted on Dec 25, 2008
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
Can a faulty 115 volt valve water prevent washing machine from working?
Sure, if it doesn't fill, it won't activate the pressure switch which in turn activates the motor to begin washing.
Jan 12, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
Apr 27, 2009 | GE WSM2780DWW Unitized Spacemaker Washer...
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Leaking water while agitating
it sounds like a bad bearing... the tub is leaking it may leak into the bearing and cause your transmission to lose oil and water ...
Nov 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
WSM2480D0WW is a gas dryer there is no heater coil... but it has a burner and igniter...if you have a electric dryer it is at the end of the blower
Jun 12, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Top load washer
I would suggest checking the pump. Sometimes a pump, whether electric or direct drive, will fail. When pumps fail they often will still work part of the time, removing only some of the water in the tub.
Nov 15, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
99 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
