Question about Crime Stopper Vehicle Parts & Accessories
Remote will not work now
I had a new windshield installed now my remote starter does not work
  • ezlite Jan 09, 2009
    Thank you , I finally got in touch with the people who installed the unit .When they cut the windsheild out they also cut the ant. wire. I had to buy a new unit because you can't just tape them back together .But of course the windsheild installers said I did it somehow and would not reimburse me .
    eezlite
  • 34 Answers
If the ant. for the system was mounted on glass it may have been disconected or if it was placed near top of dash it could have been broke or pinched thats where i would start
Posted on Jan 09, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Remote will only start when i am close to vehicle
It depends on many things - mostly the range of the system itself and especially where you located the remote antenna. Some installers don't use the antenna and that will limit range severely. Most manufacturers want the antenna routed up the windshield pillar and mounted near the top of the windshield glass. This gives best reception since glass does not hinder the RF signal. OF course, a weak battery in the remote can cause range issues as well.
Nov 25, 2015 | Car APS921 Remote Starter - Keyless Entry
I have a pre installed prestige remote starter and alarm system. It came with the (used) car when I got it. I dont know the model number and the only thing on my remote is a 1,2, lock, unlock, trunk and...
If you have the correct instructions and it asks for you to push a valet button, it is normally found inside the vehicle. Look around the lower dash and foot area and around the drivers side area for a small push button that does not look factory installed. May be red or black. If it is a newer model remote start, the button could also be on the remote start antenna usually mounted in the middle of the windshield.
Feb 20, 2013 | Vehicle Parts & Accessories
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
MY 2004 taillights keep blowing the fuse. What could the problem be and how much?
same here replaced the control box beside the windshield fluid and then all the bulbs and then the dimmer sw for the dash and now it stays on for a couple of days but still blows think it might be the remote starter or the installation of the remote starter..
Jan 05, 2011 | 2004 Nissan Maxima
Astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Jan 03, 2010 | Astra Car Alarm And Remote Starter,...
Need programing for ast ultra remote car starter
You turn the key off to on, off to on, off to on;
Leave key in "on" position, then push and hold the little button on the antenna on the windshield - keep holding this button down on the antenna, and you'll hear 5 chirps; then push the unlock button on your remote control (and on your other remote control if you have two), then release the button on the antenna and then turn the car off.
You should be able to lock and unlock your doors now. Then try the starter. Do a Google search, and you'll find more Ultra info including a little video how to program your key fob.
Oct 14, 2009 | AST Vehicle Parts & Accessories
Car will not start using the key fob all fuses are good, lock/unlock buttons work. i have had this remote starter in this car for nearly 3years
In some cases, if you hold down a button too long on the remote fob, the starter module goes into a setup "menu", which is possible. You didn't change the fob batteries lately, did you? It sounds like you will have to 'retrain' the fob with the starter unit so that it re-learns what to do when you push the start button. With the "Ultra" brand, you use the button on the windshield antenna to retrain your unit. I'm not sure about the Autopage brand. An installer should be able to reprogram it for you for $10, and that would be the easiest if you can't find the data by doing a Google search.
Oct 02, 2009 | Autopage Vehicle Parts & Accessories
Broke remote and bought new one
lick on this link and go to contact us . call tech support and they will help you. http://www.bulldogsecurity.com/
Jan 16, 2009 | Remote Starter with Keyless Entry
Remote starter stopped working
Will you rate my answer from my clarification as a solution about the antenna thanks Mike humble.
Dec 11, 2008 | Vehicle Parts & Accessories
Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Dec 01, 2007 | Scytek 2000RS-M Remote Control
Vehicle Parts & Accessories Logo
376 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Frank Mangiapane
Level 1 Expert
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
