Question about Toshiba gigabeat X20 (20 GB) MP3 Player
No Data Found
I have the gigabeat model MEGX30. The first time i loaded some songs onto it through the gigabeat room software all was good. I then reconnected my player to my computer to add additonal songs. I was half way through loading several songs when it froze so i selected cancel. When i then turned on my MP3 it was wiped. I have tried to now add songs to my player from my computer and it shows that the new songs added are on my player but when i disconnect from my computer and turn on the MP3 player and select audio it says "no data found" even though when i look at the MP3 player on gigabeat room or on "my computer" it shows the files are on the player. I have tried removing and re installing the gigabeat software and have reset my MP3 player back to factory settings but nothing seems to work. Should i take it back?? I have only had it about a month.
SOURCE: Gigabeat Room
I've got the install CD that has gigabeat room 2.02 - US version. if someone wants it - email me the request and I'll email a zip of the whole CD. it's only 29 MB (kelly . piper . cherokee at gmail . com) remove spaces...
Posted on Apr 17, 2008
SOURCE: gigabeat room driver
yes i need gigbeat room
Posted on Dec 10, 2008
SOURCE: Gigabeat room fails to recognize my Gigabeat
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Posted on Dec 29, 2008
SOURCE: Gigabeat Room Can't Detect Gigabeat on Vista
The key is to have the GB watcher run under XP mode and administrator rights. When you start up the GB Room right click on the program and run as administrator. It runs every time for me. I have the F20.
Posted on Apr 10, 2009
SOURCE: Need Firmware for Gigabeat MEGX30
no system found on hdd
Posted on Jul 29, 2009
  • 4 Answers
SOURCE: Gigabeat room will not recognize my gigabeat
I was investigating other Toshiba F40 issaue and came across this thread. This might help you.
Posted on Jul 30, 2009
0 characters
1 Points
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Could I please have more instructions on how to restore firmware data as I am still getting same results. "NO SYSTEM FOUND ON HDD" 00200060
Just install your software that came with your Gigabeat. After installation please run the following program. Start/Programs/Toshiba Gigabeat Room/Formatting Utility for Gigabeat. This will place all the files back in the hard drive. Please do not format this unit from My computer to the drive letter. You end up deleting the system and boot files. if that does not help try this in your software you right click on your gigabeat room and open it up and find gbsytem folder drag and drop into your gigabeat on your my computer screen. and then check out.try it couple of times.many times this does work for first time directly. -------- you can also try contacting topshiba service center click the link directly ---------- try downloading the firmware again and installing it in your device click this link directly for firmware ----- This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Oct 22, 2009 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
Problem with TOSHIBA gigabeat model MEGX30
I have manual and driver for MEGX30. Let me know if you need it.
Nov 18, 2008 | Toshiba gigabeat X20 (20 GB) MP3 Player
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat (60GB): How to put movies on?
Yes you can put movies on Gigabeat but it's time consuming and takes 3 programs to do it. We use DVDfab Platinum,3GP_Converter and Windows Media Player. If someone out there has a simpler way please post. 1st. Rip your movie to your hard drive and remember where you put it. (We've found using DVDFab Platinum it's easiest since we have PSP, Gigabeat & I-Pod and it offers a conversion program for all plus burning our home movies is a cinch.) 2nd. Open your 2nd conversion program (we use 3GP_Converter) and drop your burned movie files into it. We love the 3GP cause you just drag & drop. I don't know why the Gigabeat needs an extra conversion but it does, my PSP is easier to get movies onto. =( 3rd. Open your now fully converted movie with Windows Media Player. And you know the rest: just sync. While I love my Gigabeat it's pretty ridiculous to have to do all this to watch one little movie because it doesn't always work. However, unlike my PSP I can put a whole bunch of movies & pics & music on my gigabeat without running out of room! My husband is a computer geek and has tried several programs and this is the easiest way he's found to rip movie, yikes!
Mar 10, 2007 | Toshiba Gigabeat MEG-F60S (60 GB) MP3...
When you attempt to charge the player does they screen display the image of the charging plug? If not the battery may have died, in which case it needs to be replaced.
Jan 20, 2007 | Toshiba gigabeat X20 (20 GB) MP3 Player
MP3 & Digital Media Players Logo
49 people viewed this question
Top Toshiba MP3 & Digital Media Players Experts
Lawrence Oravetz
Are you a Toshiba MP3 and Digital Media Player Expert? Answer questions, earn points and help others
