Question about Garden
23 hp kawasaki on a cub cadet tank, hard to start, backfires through carb and will then start, have drained tanks put in new gas new fuel filter and air filter, Whats do I need to check on next?
Will crank and crank then start poping back through carb and sometimes will backfire loudly and start to run, runs fine when you get it to start, Dont know what to try next?
  • 40 Answers
SOURCE: cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Posted on Mar 12, 2009
  • 25 Answers
SOURCE: 2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Posted on Jun 22, 2009
  • 59 Answers
SOURCE: Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Posted on Jun 27, 2009
  • 22 Answers
SOURCE: My 2166 Cub Cadet pops and backfires at high rpm.
try replacing the air filter first or check it with the filter off, you may only need a new filter. if not get a mower or bike shop to test the coil they will let you which one to buy
Posted on Jul 20, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
Mower w/ kawasaki FR651V engine, cranks, runs 10 minutes, cuts off. Tried plugs, fuel pump & coils. whats next?
kawasaki are dirt and water sensitive chang full filter and clean carb out remove old gas from tank and clean good then refill with super unleaded gas should fun good then
Sep 20, 2014 | Cub Cadet Garden
Kohler engine command pro 27 hp not start cub cadet m60 tank
spray some starting fluid in carb if starts ether bad feul filter or fuel pump or need to rebuild carb
Jul 23, 2014 | Cub Cadet Garden
Why wont my 12.5 hp kohler engine not run full throttle and loss of power
it sounds like your carb is gummed up. You can TRY something called SEA FOAM (you can get it from Napa), you put it in your gas tank. It's the poor man's tune-up. Otherwise, you can get some spray carb cleaner and pull off your air cleaner and spray it in there. Hope that helps.
Jul 17, 2014 | Cub Cadet Garden
Cub cudet 31p7770299e1 briggs stratton engine
only thing left is valve seat is loose and poping loose at a certain rpm causing backfire threw carb has to be intake valve
Apr 23, 2013 | Cub Cadet Garden
Hello I have Cub Cadet LTX 1050 VT Sv720 23 HPEngine Kohler
This situation is just a clogged fuel line IN the tank. It happens. Yeah, stuff that gets In builds up in the line an elbow and plugs it up. Just pull the connection out of the tank and clean it out. I have even found plastic bits clogging the line on mine. I have a LT 1050 also. And a Cub ZT I just love.
Apr 26, 2017 | Cub Cadet Garden
Cub cadet 1050 fuel problem
Hi, I found manual on amazon, so you can check there for solution: International Farmall Cub Cadet 1000 Operators Manual Paperback July 20... I hope I have helped. Cheers
Jul 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
