Question about RCA MM36100 36" TV
RCA MM36100 color problem
The TV works fine until the other day. When I turned it on, the color was all messed up. The colors forms 3 static rings on the screen, the blue in the center, green in middle and red in outside. The picture displays OK, just the color is no longer moving with the object on TV. So now I am watching b/w TV with 3 color rings. Please help. If more info. is needed, I would be more than happy to provide additional info. I wish I can put a picture here.
  • Fred Dai Aug 12, 2006
    Thanks for the solution!
    I have a speaker may be too close to the TV, will that be the cause of the problem? If so, will the problem go away once I move the speaker away from the TV?
    President:
  • 3,130 Answers
Sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Posted on Aug 12, 2006
  • Larry  Dillon
    Larry Dillon Aug 12, 2006
    It should after turning on the set from a cold start
SOURCE:
Why are my tv colors so messed up?
Check the color system setup. Make it 'Auto'. Refer its user manual for details. If this do not help you, chroma section circuit should be checked. It is a skilled job, and need tech support.
May 24, 2012 | RCA Televison & Video
I have an RCA 36 inch tv, the color is messed up, it has a round circle and it will not change channels
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 23, 2009 | RCA F36650 36" TV
Color ghost
Sounds like your convergence is off. Go into your menu and try setting your convergence. If you can not move any of the colors you need to have your convergecnce amplifers replaced
Apr 08, 2009 | RCA HD52W56 52" Rear Projection HDTV
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
My rca television works fine exept for the sound
There is a switch on the back of the TV that toggles between the built in speakers or the external speakers. Try flipping it and see what happens.
Jul 21, 2008 | RCA MM36100 36" TV
Rca tv mm36100
There is a common problem in this unit with R14103 (33k 2watt ) resistor that opens. When open SMPS will not load so no other voltages beyond the 5v source to click the relay.
Another possibility is the Horz. drive transformer, RCA p/n# 243859 board location T14451.
Either of these possibilities are inexpensive fixes reletively speaking, so I would advise having it estimated by a qualified shop for repair..
Bill
Nov 24, 2007 | RCA MM36100 36" TV
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
RCA 27"
I suggest you check your Direct TV box. It may be off frequency. Stargazer
Jan 05, 2007 | RCA 27F650T 27" TV
RCA MM36100 36" TV Logo
103 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
