Question about Toshiba Televison & Video
My Toshiba flat screen TV won't stay on it turns it's self off after 5 seconds why is that?
SOURCE: My 37'' Vizio Flat Screen TV keeps shutting it's self off
I had a problem with mine shutting off randomly and (luckily under warantee still) the guy came out and replaced the mother board. If you're under warantee still just call vizio.
Posted on Feb 21, 2009
boltthedog
  • 24 Answers
SOURCE: Logik flat screen TV stays on for about 2 seconds
fluty power lead?
Posted on Sep 19, 2009
  • 1156 Answers
SOURCE: My Mitsubishi HD1080 medallion projection
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.This will help.
Posted on May 17, 2011
vinceisaac
  • 2432 Answers
SOURCE: My son is in Stanley
hi the problem with your tv is with in button key controller board, here are the ways on how are you going to fix the problem.
  • open the back cover of your tv with the use of philip screw driver to gain access the button controller.
  • remove the connector and then detached the controller board, spray the channel up/down button with a electronic contact cleaner to have good contact.
  • if the buttons are worn out you can replace only the buttons just buy at any electronics store, you can also buy or replace the whole button key controller if you want. there are sites in an internet which provide button key controller for tv like for example you can inquire here.
  • now after you replace with new button controller reinstall the connector fix it not to loose and then placed the back cover of the tv unit and screw it.
  • plug the power cord then turn on the unit. good luck i hope it will help you.
Posted on Jun 10, 2011
Testimonial: "Thank u so much. If this works it will save us so much money. I'm disabled and live on a very limited income. Thank u. Thank u. Thank u."
SOURCE: Hi, My Toshiba TV won't come
hi im having exactly the same problem with toshiba 40bv700b
eont come off standby tv only few weeks old
Posted on Jul 10, 2011
Toshiba satellite c655d screen won't come on
Try holding the power button in when your booting for 5 seconds, not long enough for it to shutdown again
1. push it to power up leave your finger on it for 5 seconds
Let me know
Mar 29, 2013 | Toshiba Satellite Computers & Internet
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
Why does my tv turn off by it's self after a few
Either a power board problem or something in the set is pulling the power voltages down---if under 26 inches it may not be fixable.
Mar 19, 2012 | Emerson Televison & Video
The power won't stay on..it turns on for a second then shuts back off
Unplug the set see if it resets. Plug back in after 5 minutes to see if it works then. Otherwise you need a tv repair shop.
May 16, 2011 | Televison & Video
PUT IN A NEW LAMP BUT NEED TO KNOW HOW TO RESET TIMER. THE WORDS STAY ON THE SCREEN FOR 1 MINUTE.
Turn the TV on, and once the timer leaves the screen (after 1 minute as you say) you do the following.
Hold both the "Volume Down" button on the TV it's self and the "Split" button on the remote for at least 5 seconds. That should reset the timer.
Jan 21, 2011 | Panasonic PT-44LCX65 Television
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Televison & Video Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
