My furnace cycles too often. Do I suspect that my Honeywell digital thermostat (Model CT3500A) Smart Recovery features are faulty? How to you adjust the sensitivity? Thanks!
  • lilamy Oct 24, 2008
    It helps somewhat as it narrows down the causes. I don't have the instructions as I bought an existing house. No luck in finding the manual at Honeywell site even though I think the thermostat model is about 4 years old. Model CT3500A). Thank very much jasond1011.
  • Anonymous Dec 06, 2008
    I replaced my old furnace in the spring, with a 2 stage Trane XL80. I had also replaced the old 1 stage thermostat with Honeywell's RTH8500. The furnace comes on every 10 minutes, runs for 5, and the temperature holds steady at the 21 degC setpoint. The older Hunter thermostat (also electronic) did not cycle often. Although the comfort level is improved now, my natural gas consumption has gone up over same period last year, by 10+ percent. I am very disappointed, and though I'd be saving money by upgrading the entire system. Not so.
    Novelist:
  • 124 Answers
Recovery has nothing to do with on off on off. you have a new digital stat that holds an exact to the degree temp a change of a half a degree can bring it on.. so stat needs to be above main return 5 feet off floor. away from any drafts , doors supplys etc. also be sure the hole in the wall is sealed . the cold air in the wall is more than enough to make stat come on . they are incredibly sensitive.an old mercury bulb stat would have a swin g of 3 or 4 degrees . so set at 75 it may heat up to 78 and stay off till temp fell to 73 so you get a longer run cycle or and longer off cycle. the new ones are on off on off keeping a perfect temp 75 exactly. thory is the heat exchanger is already hot and a quick short cycle is more efficient than being off 20 minutes and reheating the heatexchanger from scratch again. having said that if you look aT the installer set up instructions that came with the stat it may give you an option to reset or adjust the stat so it will have a one (default) two, or three degree adjustment , so 75 equals up or down three degrees on call for heat.see honeywell toll free number in their literature
Posted on Oct 24, 2008
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
I have installed a new Honeywell CT87 non-mercury manual thermostat. It runs but the the furnace turns off the room temperature alway at or beloe the furnace setting so the furnace turns back on again and...
Hi, these mechanical thermostats have what is called a heat antcipator on them. If you remove the cover you will see in increments or numbers such as 1.0, o.1, .2, .3, .4 or o.1, 2, 3, 4, . The stat and main gas valve work together and have to draw the same amount of amps to cycle the unit properly. This stat will have a copper arrow pointing at a number. A good place to start is to set it at .4. If the unit does not cycle right, set it at 1.0 and go from there until it cycles. Let it go through several full cycles during each time you adjust it until it is correct. These are good dependable stats as I have many on my service truck. If it doesn't take care of the problem, take it back and return it for one that is not faulty which happens often. Best of luck to you.
Ps, the small manual that comes with a new stat has that information on it, anticipator settings.
Shastalaker7
A/C, & Heating Contractor
Mar 11, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I have a Honeywell programmable thermostat with a York high efficiency furnace. To turn the heat on, the thermostat "clicks" and cycles the furnace through startup (warm the fire starter, turn on gas,...
Well, it is a computer, and they all glitch, now & then, you say it clears with a power off, and thus resets it, It maybe a thermostat, flaking out, they do that, but the 6'o'clock, thing being the "Or" that sets it apart, I wonder if it isn't just a faulty control unit, as two together is too many, for a single cause, now, it sort of points there, but also, may sound silly but first, of there is any, Check your backup battery..
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell ct3200 with a trane xl 80 furnace. it will cycle on to the right temp, go off and cycle the furnace back on 30 seconds later. Is that normal? It is 32 degrees outside, set at 68
Hi, check page 22 in your manual, it says "Adjust the screws on the back of the thermostat as instructed on page 7." Your furnace is a 80% efficiency but is also a high efficiency 2 stage heating system so try adjusting screws A and B both ways and see which gives you the correct cycling.
Your manual is here:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
CYCLING TO OFTEN
You need to adjust the heat anticiptor on the thermostat. Not knowing your furnace control amp draw ..... I would set the anticiptor somewhere between .3 & .7. The slight adjustment should make the cycling run better. If not adjust it the other way. If this does not solve the problem the heat anticipator might be bad (change the thermostat). If you have a digital stat read the manual most are preset at the factory. Sometimes you can reset it by following the directions.
Mar 25, 2009 | Honeywell Electronic Programmable...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Adptive intelligent recovery
On the Pro4000 model you hold the 2 arrows until you go into setup mode. Then arrow up ONLY til you get to option 13. The display will read 13 and 1, press the DOWN arrow and it will read 13 and 0. This turns off Adaptive Intelligent recovery. Now hold the 2 arrows til you see the normal display screen. You are done.
I just did this with a Honeywell tech rep on the phone.
Nov 15, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
5,997 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
