Question about Lanier Office Equipment & Supplies
I have a LAnier lp226cn and need o find out how to scan documents to email Please and Thank you
I have a lanier LD122 - error code is sc541
Posted on Nov 02, 2008
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Sep 11, 2014 | Lanier Ld 430c With Feed, Bank, Print,...
I have a Lanier LP226cn printer. Under the alert status it is telling me to ''Prepare a New PCU'' and ''Replace CPU Black Soon'' I understand it means to replace my Black Toner soon as someone mentioned...
Sorry, You do not need Black toner, you need a Black PCU (Photo Conductor Unit).
I have this same printer with the same warning.
Unfortunately, This unit seems to be rather expensive.
Good Luck
Mar 01, 2010 | Lanier Office Equipment & Supplies
Computers crashed due to an outage...cannot scan docs
Reboot the machine first. If that doesn't work, go to user tools - system settings - file transfer or interface settings (depending on the model) and enter and admin email address. Then go to admin tools and tell it to auto specify a sender. It is looking for who is sending the scan, not who is receiving it...
Apr 08, 2009 | Lanier Office Equipment & Supplies
I need to scan and e-mail a document please help
There's several ways to do this. I will tell you the easiest, (at least to explain).
1st- scan the document as usual, save it to your documents.
2nd- open an email, address it. Then click on the little icon at the top of your email that looks like a paper clip. This will open a box, just navigate to your documents & click once on the document that you want. This will put it in the email & you're ready to send. If you don't see a paper clip icon then click on 'insert'. This will do the same thing. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
Feb 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
Lanier copier won't scan to computer
IF you're scanning to folder, check your security settings in file sharing. Try allowing all permissions to each listed and apply.
If you there is a computer that you know definately works already, have a look at their settings in security tab of file sharing - and change permissions to allow full control (for now). See if your scanning works.
Oct 24, 2008 | Lanier Cquence M3
Lanier lp226cn error code sc545 printer won't work, maybe a fuser error? new and has not been used enough for this to happen!!! Can I re-set this?
Hold the up and down arrows together for 10 seconds, and press ok. Select 2, for engine. Scroll to 7 or data log, press ok. Scroll to 7807, press ok, execute, exit all the way back to engine, and select 3 to end. Turn printer off and on. Try it. It is a fuser code, and it just might be dirty where the sensor touches.
Jun 03, 2008 | Office Equipment & Supplies
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
I have a document that I wish to email. How do I do that please?
Hello pepaga
The information you need will be based on the email client (software) that you use and on device that you use to scan a document onto your hard disk. Please, answer the following questions:
(01) Is the document on your hard disk already?
(02) Do you have only a hard copy of the document and you wish to scan it onto your hard disk and then send it as an attachment?
(03) What is the make and model of the machine (MFC, All-In-One, scanner) you use to scan documents onto your hard disk?
(04) What email client (software) do you use?
(e.g. Outlook Express, Outlook, Eudora, Thunderbird, Netscape Mail, etc.)
Please, post back here w/ your answers and any other info. that you can provide (the more details you can can provide us with the better). We'll do our best to provide you w/ the information you need.
Thank you
BJ
Apr 04, 2008 | Office Equipment & Supplies
238 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
