Question about Inglesina Zippy AG4 Umbrella Stroller
Doesn't open as easily as it should
Hello, I purchased the 2005 Zippy around Thanksgiving, and it has only opened once as described in the manual and website. It is suppossed to be the easiest one handed opening stroller on the market, yet I have to jiggle and wrestle the darn thing open, putting my leg up on the lock down bar as I press the finger trigger mechanism. All this for $275 !!! I bought it to make my life easier, but since Inglesina's customer service is so frustratingly poor, I turn to you. Except for the opening mechanism, the stroller is fine and runs smoothly. No problems closing it. Any help would much appreciated. Thanks for your time, Teresa
4 Suggested Answers
SOURCE:
SOURCE: I need a replacement front safety bar for my
I think you can call them or complete an online form to inquire about replacement parts here:
http://inglesinaonline.com/info_replacement_parts.asp
Posted on Jun 09, 2010
  • 286 Answers
SOURCE: The handle on my Inglesina
hi
I'm not sure if you can replace just the handle you may need to replace the frame but i have found contact details for inglesina in italy they cover most of the world by the looks of it they may be able to help
http://www.inglesina.com/en/consumer
here is the usa contact also
http://www.inglesina.com/us/consumer
and the instruction book on the last page is a phone number
http://www.inglesina.com/sites/default/files/ZIPPY%20STRIPTEASE%20-%20447024ZB_5.pdf
Posted on Oct 19, 2010
  • 286 Answers
SOURCE: We bought a inglesina stroller
hi here is the instruction manual
and a video to help
http://www.youtube.com/watch?v=sPI5wrDYE78
Posted on Mar 12, 2011
How i open my sitting seat ?
hello, I did some looking for you and found this article which describes exactly what to do, also a useful link, hope this helped you have a great day
Typically, Honda seats have a bolt at the rear and one on either side. Remove the bolts, the seat comes off easily. This process is described in your owner manual which should be in its space behind one of the side covers. In that same space, you should find a tool kit with the tools required to remove the seat. You might want to check out this site ... http://hrca.honda.com/publications/. Some Honda batteries come out the side. Some other Honda motorcycles have a seat which unlocks and opens up in a similar fashion to a glove box in a car. The battery is easily accessible in this style. I don't think yours is this style, still this is good information to have.
May 26, 2015 | 2011 Hero Honda Pleasure 100
"automatic" window on my 2005 mustang does not
So when it doesn't seal that means the tracks the window have been falling out typically. The door panel needs to come off to inspect the tracks. And if your driver side power window doesn't work, that typically means a seperate problem located in the switch itself. It could also be the wires, so you can run a seperate wire to test the switch by running it directly to the window motor, and pressing the switch down. This can easily be done while the door panel is off so you can hit two problems at the same time.
Oct 20, 2011 | 2005 Ford Mustang
We bought a inglesina stroller zippy 8 at a yard sale and can not figure out how to open it. Any suggestions?
and a video to help
Mar 12, 2011 | Inglesina Espresso Stroller
I purchase a Whirlpool duet sport in Feb 08 and since Thanksgiving of 09 it has been retaining water in the fabric softer department. I have removed it and cleaned it out several times but to no avail.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Chamberlain 1/2 HP door opener will not work (102 1499A))
sounds like the clutch in the motor is slipping, perhaps the chain is getting kinked on something. check to make sure there is nothing in the way of it and that it is on track going into the motor
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Honda Odyssey 2005 sliding doors won't open, beep 3 times
If you click once your remote control ,will open just driver side doors.To unlock all of them have to press twice , and then sliders.
Apr 11, 2009 | 2005 Honda Odyssey
Car won't start after using Auto headlights on 2005 Lexus LS430
The trunk should auto close when you manually lower the lid to the almost closed position, but it is NOT designed to open up fully when you hit the trunk release on the key fob, nor when you open the trunk manually using the touch sensitive button under the lip of the trunk.
Feb 02, 2009 | 2005 Lexus Ls 430
Hotpoint RB757 DOOR LOCKED CANT OPEN NO MANUAL PLEASE HELP
act like your going to self clean and start from beginning and set it to self clean ,,, after you hear it lock down and start to go in clean the cancel it out and it will open / have a good thanksgiving
Nov 26, 2008 | Hotpoint RB757 Electric Kitchen Range
It is xp
use a straightened paper clip and push it firmly but lightly into the tiny hole on the front of the drive. the door will release. once opened, remove any media and try to open and close it using the open/close button on the front of the drive. if it does not work, the gear or the mechanism has been damaged. you can purchase a new one for around $40 and replace it easily.
Nov 26, 2008 | Dell Dimension 2400 PC Desktop
Panasonic AG-DV1000 ejecting tapes
This unit just needs the standard belt job. The rubber parts probably got old sitting around in the back romm of the university.
Could do it yourself if you are the like to take things apart type. Otherwise, a repair shop can do it very affordably.
Dec 16, 2007 | Panasonic AG-DV1000 Mini DV VCR
Inglesina Zippy AG4 Umbrella Stroller Logo
62 people viewed this question
Top Inglesina Baby Gear Experts
Marvin
Marvin
Paul Carew
Dorel UK
Dorel UK
Are you an Inglesina Baby Gear Expert? Answer questions, earn points and help others
