Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cost of starter solenoid Briggs & Stratton 19.5 HP Twin Craftsman Turbo Cool riding lawn mower?
VanHuben
  • 5 Answers
SOURCE: Lawn Mower won't start
Its a thing of beauty to see problems solve themselves. It seems to me this trial and error approach is very taxing and could have been avoided if 1, your small engine repair guy/Craftsman/Sears had sold you the right parts from the start, or 2, you had bought the right part... from the start.
Posted on Oct 24, 2008
  • 160 Answers
SOURCE: oil quanity
usually 1 qt
Posted on Nov 12, 2008
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
suzukiracing
  • 200 Answers
SOURCE: engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Where is the solenoid located on a briggs and stratton engine model number 282H07/0334
Mary Jo, solenoid is not normally on engine, follow the positive battery cable from battery to where it bolts to a small double terminal device(this is the solenoid) the other bolt has cable attached that goes to battery.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mower Starter Solenoid Replacement Craftsman Riding Lawn Mower Repair Part...
Replacing Solenoid on Craftsman Lawn Mower or Tractor
Mar 24, 2016 | Briggs & Stratton Garden
What is the air gap between the flywheel and coil on 22 hp
.030 (thirty thousands). I use brass shim material as it is not magnetic.
Jul 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
What is the torque sequence on a 18 hp. v twin motor briggs and stratton motor
If your talking about the cylinder head bolts. I don't know the exact sequence but I was a truck mechanic for forty years and went by the rule of thumb to start in the center and work towards the ends. That way you avoid a buckling o9f the head.
Jun 16, 2014 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a 1998 Craftsman 19.5 HP opposed twin turbo, and it wont start without taking the right plug out, which releases compression, and then put it back in, and the cylinder will fire and run accordi
You might try putting an inline valve in the fuel line feeding the carburetor or simply clamp the line shut to see if that works.
It sounds like hydro lock due to fuel getting into the cylinder when the engine is not running, Briggs had an issue with it along with others, some (like Honda) have a solenoid in the float bowl to stop the fuel flow. If this works install the valve, shut it off and let the tractor idle a minute before shutting down the engine
Sep 19, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I clean the flywheel on my Craftsman/ Briggs & Stratton lawn tractor
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Aug 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
171 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
