Question about LG Refrigerators
I have a broken gear on the bottom freezer door on my LG french door design. I put it back in place but it is only holding by 2 dogs instead of 4. Any idea where to get a new gear? Model is LFC22760SB.
  • 1,543 Answers
Find service centers at http://us.lgservice.com/index_b2c.jsp
Posted on Oct 24, 2008
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
LG French door refrigerator bottom freezer not working
Check inside vents are clear and door seal is good. Check air compressor area is clean and well ventilated. Put setting in a low number and turn off / unplug unit, count to 10 and plug in, turn on.
Crossing fingers helps too ;)
Mar 30, 2014 | LG 7841 Bottom Freezer French Door...
How to replace the light bulb in the Maytag french door bottom freezer
Hopefully you have figured this out. Its fairly simple to do. If your freezer if full you will need to empty enough that you can place your hand in and on the Plastic Light cover. Its in the center at the top of the freezer. This cover is removed by simply applying a little pressure to the right and left corner and pulling toward you and down. The light cover with very little pressure should mover and pull down. Once it begins to lower in the back just keep a hold of it and mover your hand toward the rear of the freezer and the front tabs will slide out.
After changing the light bulb, simply put the front two tabs of the front of the cover in first and snap back into place by pushing up. Takes about 3 minutes to change the light bulb. Good Luck!
Dec 24, 2012 | Maytag MFD2560HES Bottom Freezer French...
How do I remove the bottom freezer door from an lg refrigerator. Can't get it through the doorway?
After 9 days I imagine you have solved your problem but for those searching for an answer this is what we had to do. In the owners manual on page 15 it tells you to open the drawer fully, remove the lower basket (large one) by tilting the door. Now it states to press both hangers with your thumbs to lift it up. "Hangers" had us stumped. They are little notches, latches that you press in (depress) to release a locking effect, if I remember correctly each side has 2. This allows you to remove the white plastic rail covers. Next remove the 2 white screws; one on each rail near the bottom front. Then with both hands, hold both sides of the freezer door and pull up to separate it from the rails. We not only had to remove the freezer door but the 2 french doors as well. Hope this helped
Aug 18, 2011 | LG LFX25960 Bottom Freezer French Door...
Frost on back wall of freezer
There is a door that is not closing 100% of the time. There is warm moist air entering the fridge and building up on the back wall.
Make sure all doors are closing. Sometime the bottom door will close on one side but not the other.
Good Luck.
Jul 24, 2010 | LG LFX25960 Bottom Freezer French Door...
All of the lights on the front are out and it says Err FF how do I fix this?
You have a bad freezer fan located in the back wall of the bottom. If you unplug the unit for 4 hrs and plug it back in and it works the fan is freezing up. There are service bullitens on this for a new design fan but you have to pay for the service call. Only thru an authorized LG dealer.
Jan 05, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
Really Noisy
There is a new computer board that has to be installed and the freezer defrosted to solve the problem.
Nov 25, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
74 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
