Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Blue screen I've been having this problem for a while now, tv screen would turn a bluish-grren then back to color, back and forth for a while. Now it's just totally bluish-green. My question... what's my Tv's problem???? Help...
    President:
  • 4,402 Answers
Replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Posted on Jan 22, 2008
SOURCE:
I have a Mitsi WS-65807 65" Played Wii for about two hours. Lost sound then picture. Now it wont turn on. Just get a warped bluish screen with lines. Any Suggestions?
Well i need more info. have you tried unplugging the tv for around 60 seconds? Was the "warped bluish screen" right before it died. Or is this when you turn it on it happens?(Bluish screen)? Because if no power at all and no picture at all. Could be Power supply. If you have some sort of picture with blue lines that are stable? You have a convergence problem. Get back to me with info i can help.
Dec 26, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Blue color on tv screen
u have bad optical block , call sony about it u tv may be still under recall because this problem
Apr 16, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
All DVD movies are bluish. How to adjust color to be natural?
if you are using component cables, check the cables for correct color configuration to your TV and from DVD Player.Example red to red green to green and blue to blue, if they check out,the possible problem might be a defective cable...
Dec 29, 2009 | Sony Audio Players & Recorders
The colors red blue shake back and forth on the ws55807 mitsubish
maybe you need to goto menu and auto converge colours..
try degauss feature if avail..
Is it a projection tv if so you may need a flyback anode block for R,B guns.
Dec 16, 2009 | Mitsubishi WS-55807 TV
BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Screen is too blue
You will have to take the front cover off, usually 3-6 screws holding from the back, when it does come off there will be wires to the control panel attached still. you will also have another panel to undo. after that there will be a block with 3 focus controls and 3 screen controls marked b g and r for the three colors. The blue screen control is the one you are looking for, be very careful the slightesr turn has huge response including shuting the tv off when you turn it the wrong direction to far
May 06, 2008 | Sony KP-51WS510 51" Rear Projection...
Screen tuens blue them tv turns off
NOT GOOD NEWS... IT SOUNDS LIKE YOUR BLUE CRT IS SHORTED. THE ORIGINAL PART IS N.L.A.(NO LONGER AVAILABLE) THEY DO MAKE A GENERIC REPLACEMENT, BUT I DON'T THINK THEY ARE AS GOOD AS O.E.M.
YOU CAN TAKE OFF FRONT OF T.V. AND ADJUST THE SCREEN DOWN ON THE FOCUS BLOCK. IT IS THE BLACK BOX WITH 6 ADJ. ON IT 3 ARE FOCUS. 3 ARE SCREEN . TURN THE BLUE ALL THE WAY DOWN , THEN WITH THE BACK OF A PLASTIC OR RUBBER SCREWDRIVER HANDEL YOU CAN TAP ON THE NECK OF THE CRT, NOT TO HARD. SOME TIMES YOU CAN CLEAR THE SHORT OUT OF THE CTR. IF THIS WORKS LET THE SET WARM UP FOR 10-20 MIN. THEN TURN THE COLOR ALL THE WAR OFF, THEN SET THE BLUE LEVER UNTIL YOU HAVE A GOOD BLACK AND WHITE PICTURE. BE CAREFUL NOT TO TURN IT UP YOU CAN DAMAGE THE CTR IF THE LEVEL IS TO HIGH. ERROR 8 IS A.K.B. ERROR THAT MEANS THE CRT'S ARE DRAWING TO MUCH CURRENT.
DON...
Nov 12, 2007 | Sony KP-51WS510 51" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
