Question about Electronics - Others
My motomaster 3000 inverter is displaying olp
My 3000 model motomaster eliminator inverter is displaying 0lp and not working
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
Oct 22, 2016 | Eliminator Electronics - Others
I have 3000 w inverter now when I turn on its saying olb and fans on back side one
Make & Model? A troubleshooting Hint: Remove & unplug everything from the AC outlet(s), still have the OLP error code? Note: Some 3000W Inverters have two inverter circuits operating in parallel, if one circuit blows its internal fuses maybe its only work on one circuit ? Usually there are a number of 25A car fuse (Qty 8) in parallel for each inverter circuit.
Unless it was overloaded momentarily there should be no reason for the fuses to blow under normal working conditions. That means highly likely they may have blown due to circuit fault.
Oct 22, 2016 | Inverter Electronics - Others
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Motomaster eliminator 2 in 1 spotlight/lantern power
I am looking for a charging cord...I moved and haven't seen it in a while. Is there somewhere i could buy one.
Dec 02, 2013 | Eliminator MotoMaster Mobile Power...
My motormaster eliminator mobile power pack 700A just started beeping. What is wrong with it?
if there is a car fuse, under the cover, remove it.
most of the time, it is only use to activate the LOW Battery alarm.
Put the fuse back, when fully charge.
Jul 10, 2011 | Eliminator MotoMaster Mobile Power...
Have an eliminator intelligent battery charger model CT-1200A 11-1513-8. Can this be used to keep a car battery charged for a period of say 3 months while car is not being used. I have this same question...
· Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
Nov 27, 2010 | Eliminator MotoMaster Mobile Power...
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Oct 24, 2010 | Eliminator MotoMaster Mobile Power...
I have 1750w mobile power inverter turn on light comes on then the falt light come on right away.
Like most Cheap square wave inverters, the mosfets can not take the inrush current.
Usually if the fault light comes on and there is NO voltage at the output, FIRST check the on board fuse, then check for any tell-tale burn spots, or areas where the components have heated up or burned.....if you get this far and all appears clear, then it is time to check the fets.
I would not reccomend any Motomaster Eliminator inverter other than the more costly sine wave unit....or stay with a 1kw unit and do not overload it.
It\s best to run as much as you can at 12vdc or higher...like 24vds. AC is nothing but problems.
Apr 10, 2010 | Eliminator MotoMaster Mobile Power...
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Electronics - Others Logo
116 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
