Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Wireing the baseboard heater
I recenty bought a fahrenheat baseboard heater, i ran 12/2 wire to wire it to a circuit breaker, i bought a 20amp double pole breaker, i also bought a single pole thermostat for the heater. the 12/2 wire has a black wire, white wire, and a ground wire, the thermostat has a black, and a red wire. the heater has 2 black wires, and a red wire, now i dont know how to read an electrical scamatic, so what i need to know is what wires get hooked together, so i dont blow the main breaker to my house, i have blown the main breaker a couple of times. any help you can give is greatly needed..............thank you
  • Anonymous Mar 19, 2014
    Do I require single or double pole circuit breaker
  • 147 Answers
I can help you if you still here.
Posted on Nov 06, 2008
  • butch welch Nov 06, 2008
    Hook blk on one pole (Screw)and white on the other pole (screw) of breaker, run white straight to heater (tie on to either black wire) run Blk from breaker to blk on stat, run red from stat to other blk on heater. Connect grd to heater and braker box
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier.
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
I'm trying to install a new Fahrenheat 240/208 baseboard heater and it trips the circuit. The old heater was the same 240/208. I initially thought I had miswired the heater but it tripped the circuit...
If the circuit breaker is tripping instantly when power is applied to the heater then you have a dead short somewhere. You need to check your wiring again. Either it is wired wrong or you have part of a bare wire that is touching another wire or to ground. If all your wiring is correct then the element could be bad or is grounding out to the cabinet or whatever. Take another good look at all the wiring. Good luck!
Dec 03, 2009 | Fahrenheat Electric Convector Baseboard...
Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
May 03, 2009 | QMark FBE15002 electric baseboard heater...
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Wireing three units together
yes, you did a good job. Sounds like you paralled them. Which is right buuuut what size are these heaters. Add the wattage of all of the heaters and divide by 120 and that is how much current you will be using. On a 20 amp breaker you can only pull 16 amps safely. I think you will be way over unless the heaters are 600 watts each. You are allowed 1800 watts on a 20 amp circuit.
Nov 06, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with 220 wire?
in a 220 setup you don't use the white wire. just your other ones. just wire nut it off
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard heater connect
I have a fahrenheat F2548 baseboard heater, there were not any wiriing diagrams or installation instructions in the box where can I find the wiring diagram,
Aug 04, 2008 | Fahrenheat Electric Convector Baseboard...
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
879 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
