Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
We have a Honeywell Pro TH4000 thermostat. The furnace shuts down before the temperature is reached and I have to flip the heat switch off and on to get the temp to raise. Do I need a new thermostat? This one is only 1 year old.
  • 518 Answers
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Posted on Mar 07, 2008
boanhtgclg
  • 34 Answers
SOURCE: New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
Accurate Joe
  • 61 Answers
SOURCE: replacing aging erratic honeywell chronotherm III
Honeywell has a great newer thermostat.
This is what I sell, it is easy to program and use and has a large touch screen. I hooked up 4 in a office and it saved them 15 % of heating bills
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8110U1003 this is the link for Honeywell thermostat for the page.
Posted on Nov 30, 2008
heatman101
  • 43501 Answers
SOURCE: Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 12, 2009
shastalaker7
  • 1515 Answers
SOURCE: Our Honeywell programmable thermostat is
Good Morning, and yes you said it. Anytime a stat doesn't come on when it is set for a call for heat or cooling, the sensor on the subbase of the stat has lost its ability to sense the correct temperature. I have seen mechanical stats last as long as 25 plus years, but that's truly amazing for a digital stat to last that long. Yes, replace the thermostat. I don't know what kind of system you have, but if its a gas furnace with an a/c, the wiring will look like this. You will have terminals marked R, Red, for the 24 volt hot wire, G, Green, Y, Yellow, and W, White for heat. Going back to the red wire, it should have RC and RH on it. There will be a normally red wire connecting the 2 terminals.The Red wire coming in can connect to either one, as they are all together. The new stat will come with the new Red jumper wire attached. So, if you do have a gas heater, this is very easy to install. The only terminals you will need to use are RH to RC for the incoming red, Y, G, and W for heat. Y is for cool, and G is for fan. Very easy. Now if you have a heat-pump, they have many more terminals and can be a problem wiring them. If you have gas, forget the heat pump. I wont confuse you by going there. If it is a heat-pump, contact me in the comment box to let me know, and I can help you there also. Get a new stat at Home Depot, Lowe's Hardware, or O.S. Hardware. You want a 5 day, 2 day programmable Heating and cooling thermostat, 24 volts.It will have everything you need. See if it takes batteries for the display, they may not come with those, it will say on the box. Turn off your power to heater, so you won't short out the new one.They come in 2 sections, first the stat that just snaps on, and the subbase that is screwed to the wall. It will have the wiring terminals on it. Remove a couple of screws and loosen wires and remove. Be sure you write down how the wires go in case they used different colors, you never know. You will be all set. Store the manual in a safe place for future use. I wish you the best.
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
PS, Please rate me on this :))
Happy Holidays to you and family!
Posted on Nov 23, 2010
Testimonial: "I hate spending money needlessly replacing items that may not be the problem. Thank you for confirming my suspicions."
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
I install 2 new honeywell non programmable thermostats. The temp never reaches the setting temp. Always 5 to 8 degrees off. I can not get the furnace to heat the home over 70 degrees. Even set at 80. Any...
If the furnace is cycling on and off and not reaching temp there is a problem in the control circuit. If the thermostat is not satisfied the furnace should be running without shutting off in which case the capacity of the furnace is inadequate because of size or problems reducing the capacity. This could be caused by an increase in home size, poor air flow (dirty filter, loose fan belts, fan running slow, obstructions in the duct), dirty heat exchanger or burner, reduced gas flow, over temperature switch bad causing the burner to shut off early, or a few more technical reasons. You may do well to call a technician to troubleshoot this problem.
Feb 09, 2015 | Heating & Cooling
Dip switch settings rthl2310
Check for cold air inside the wall behind the thermostat, a cold wall, and area that is getting hot or cold air blowing on the thermostat. Last, the heater may not be compatible with some digital thermostats. Honeywell Customer Care toll-free at 1-800-468-1502.
Aug 29, 2014 | Honeywell Programmable Thermostat Heater
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
Rth2520b Honeywell thermostat won't turn on
If known-good batteries were installed correctly, the thermostat may have failed.
Dec 23, 2013 | Honeywell Programmable Thermostat Heater
I have Honeywell Pro TH4000 series. The fan wiil not come on what do i do
Depends on what type of heat you have...gas, oil , electric, heat pump? Make sure it is the right thermostat for your heat source. Some thermostats have a switch on the back for fuel or electric.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
Thermostat keeps shutting down a/c system
A couple questions. Have you ever tried switching from auto-on while the system was working properly? And when it shuts down, does the blower in the furnace/air handler shut down as well? And the no batteries just means the thermostat is drawing power from the transformer in the furnace.
Apr 17, 2013 | Heating & Cooling
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
48 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
