Question about RCA HD52W59 HDTV Projection Television
M50WH72S Looking for the service manual, replaced the DLP bulb already and thinking it maybe the ballast but I would like the manual before we go any further into the unit. Thanks, Janette az286@yahoo.com
Go to:
http://personafile.com/RCA-50-DLP-High-Definition-Television-Stand-Included-M50WH72S-P034909000018.htm
There you will find the information that came with the TV.
Posted on Nov 23, 2008
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
Takes to long to come on
Maybe a ballast problem. DLP are famous for bad lamps and housing. You must make sure the lamp is a good and exact model replacement. Generic ones that are so called guaranteed to be exact replaments are often not and need to be sent back. And google for ballast replacement and find out how others are handling it.
Feb 06, 2015 | Samsung Televison & Video
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 2006 Thomson/RCA ModelM50WH72S TV that we have replaced the lamp, it still does not work and a technician has told us that we need a light engine for it. How can we locate one?
have the same tv,, power light blinks, book said it was bulb, bulb didnt fix it,took it to tv repair shop, they found a bad capacitor, replaced it with a higher heat range capacitor, this capacitor was on the power board for the lamp circuit, repair was $200, not bad since i paid $1500 for the tv, other than that issue, just replaced a couple of lamps
Dec 28, 2010 | Televison & Video
Projector turns on but does not illuminate bulb is good
may be either the colorwheel or the ballast. if you hear the colorwheel spin up (high-pitched whir), replace the ballast. if you don't hear it, replace the colorwheel.
Dec 11, 2009 | Sharp XR-10S DLP Projector
No sound no picture and new bulb red and green flashing lights on power up.....
The problem is either the lamp ballast or the light engine. My guess is the ballast. Part cost ranges between about $75 to $150 depending where you get it. If you're handy you can replace it yourself. I posted the process elsewhere on this site for another Toshiba DLP question (I think it was for a 46HM84). Good Luck.
Jun 21, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Hlp5063w 50'' DLP samsung Experiancing The Word LAMP green letters flashing for 20 second followed by clicking noise then shut off.. then repeats that same process twice then TIMER / STANDBY/TEMP/LAMP...
Sounds like you've already gotten into the repairs. The three major things that fail on DLP are the bulb, the ballast and the color wheel. If your bulb is new and you aren't getting anywhere, replace the ballast, if that is still a no go, then move on to the color wheel. If replacing those three doesn't fix the problem, you will have to whip out the multimeter and start looking for problems on the PSB. You can get a ballast on ebay for about $100. Start there. The color wheel should be very freely moving. If something is grinding and hindering the movement at all, you need to replace it. That grinding may not seem like much but it is likely enough to keep the wheel from spinning at proper speeds. The sensor then kicks in and tells the brain that there is a problem and the brain keeps the ballast from firing the lamp.
Good luck.
Feb 18, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
No picture and i replaced the bulb
Joe,
I've never heard of a color wheel costing that much even with labor included - I think I'd try to find another tech for his advice.. If you have trouble locating one try NESDA or let me know what city/state you're in and maybe I can help recommend someone.
That said, if the lamp is good the next logical thing to check is the ballast. If the ballast is not supplying voltage to the lamp then it clearly won't light. A ballast is not that expensive, similar to a ballast in a floresent light - only a bit more complex. In any event I would strongly suggest finding a real professional first we are out there...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Dec 02, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
More on Ballasts from Alanx
By looking at the photo of the ballast on eBay, it doesn't appear to match the one that is in my television, but I haven't looked at it lately, but I will check it later this week and see if it perhaps matches. My set actually has a new bulb already in it, so I really won't need other bulbs right now since I don't have any extra money for backup parts. I might be interested in your ballast if our tvs take the same one; but like I said, I'll check later this week when i get back home and I'll let you know if it fits or not. Thanks, -Travis
May 11, 2008 | LG RU-44SZ63D Television
Rca dlp schematics
what chassis number is your set? Should be an ATC number on the rear of the set. Let me know that number as each series DLP is different for voltages
Feb 15, 2008 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
530 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
