Question about Samsung ML 2010 Laser Printer
How to replace toner cartridge on samsung ML-2010?
Replacement seems to slide back out and will not stay in place.
  • snapplekid Oct 26, 2008
    it seems that 37 times is the charm. tried to slide the cartridge back into place that many times however, it did not 'take' until the 37th time.
  • 35 Answers
I've got the exact same printer. If you push it all the way in you should feel it click into place. If you don't it means, either the track that it slides in on is damaged, or you got the wrong replacement cartridge.
Posted on Oct 24, 2008
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Oct 26, 2009 | Samsung ML 2010 Laser Printer
Samsung ML2010 printing blank pages after toner replaced
Reputable or not, every once in a while you get a bad one (even originals). It's obviously defective. Return for a replacement
May 19, 2009 | Samsung ML 2010 Laser Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
CRU Fse error
Was the "Off Brand Toner" a used refill cartridge? Usually this error is caused when the drum (That statically attracts the toner to it) has worn out. This can be caused by too much light exposure, or just from overuse.
I would suggest bringing back the cartridge where you bought it from and asking them to switch it out.
Oct 22, 2008 | Samsung ML 2010 Laser Printer
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Fain printing
I'm using remanufactured toner provided with my ML-2010 by Discount City when I purchased the printer and I'm having the same problem.
I have used non OEM toner in other laser printers also with disasterous consequnces so I think you'll have to 'bite the bullet' and purchase a new Samsung toner cartridge unless you can find out who manufactures the cartridge in which case you might be able to souece one directly avoiding the extorionate mark up.
Jun 19, 2008 | Samsung ML 2010 Laser Printer
Stopped printing after I installed new Toner!
If the new toner is original, your unit just burned the fuser. If it is under warranty, any Samsung Authorized Service Center will gladly replace it for free.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
61 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
