Question about Zanussi Ovens
How do i fit a new oven door catch on my Zanussi zkg5540xfn purchased 2010 ?
Bought the new catch for my oven, but have no idea how to fix it, no sign of how to fit in the manual, i did find a plan/diagram somewhere online, but cant find it now :(
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: how to remove the glass from zanussi oven door
There are 3 'Do-It-Yourselfer' stories about installing this part
Posted on Jul 13, 2008
  • 120 Answers
SOURCE: Removal of Zanussi oven door
Hello tracey,
Yes i may be of assistance to your dilemma, if you notice the hinges on the bottom of the door you should be able to open it slightly and gently but firmly pull upwards and outwards which will allow the door to prop off. i would suggest placing the door on either cardboard or a soft rug. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Posted on Nov 11, 2008
SOURCE: oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Posted on Feb 28, 2009
  • 196 Answers
SOURCE: The element has blown on my Zanussi ZBF860 oven. I
You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
Posted on Mar 15, 2011
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
Mar 15, 2011 | Zanussi ZBF360 Electric Single Oven
Oven door lock pin broke
how did you fix it?? i have the same problem!! :(
May 12, 2010 | Ovens
Can i purchase a replacement seal for around the
That seal you should be able to order from any appliance spares supplier the Zannussi part number is. 3577252020. cost in euros. € 10.20 + vat.If it is the one I think it is then it is not easy to fit.The screws around the whole front panel have to be slackened off and the front prised forward dont take off fully pull old one off the new one has to be pushed in behind lip then fix all screws.may be easier with door off.
Hope I helped.
Apr 25, 2010 | Zanussi ZBF260 Electric Single Oven
Are there replacement door hinges available and how difficult are they to replace
Door hinges are usually available to purchase as a seperate item, you should replace them both together, usually, they are fairly easy to fit.
Mar 08, 2010 | Zanussi ZBM799X Electric Single Oven
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Hello tracey,
Nov 11, 2008 | Zanussi ZBQ665 Electric Single Oven
Purchase of new part
Try 3wire.com or northernparts.com
Aug 26, 2008 | Zanussi Ovens
Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Jul 01, 2007 | Zanussi ZBQ365 Electric Single Oven
Ovens Logo
52 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
