Question about Canon Pixma MX410 All-In-One Printer
Canon MX410 won't scan from the adf
Used to copy from the adf but stopped for some unknown reason
Thank you, old marine! That fixed my problem!
Posted on Oct 13, 2015
5 Suggested Answers
old marine
  • 1992 Answers
SOURCE: having problem copying from ADF
On this model, the Intensity needs to be set to 'Manual' to make copies from the ADF.
1. Press the 'Settings' button repeatedly until 'Intensity' is displayed
2. Press the left or right arrow until 'Manual Adjust' is displayed, then press the 'OK' button
3. Press the left button to decrease the intensity, or the right button to increase the intensity, then press the 'OK' button
4. Press the 'Back' button repeatedly to return to the Copy standby mode
To return to 'Auto Adjust', follow the above instructions selecting 'Auto Adjust' at step 2, and skipping step 3
Posted on Aug 28, 2009
SOURCE: My Canon MF4150 multifunction device
Hello I just figuered out this problem. When the paper is feed thru the ADF ( Automatic Document Feeder ) there is a plastic piece with a plastic film. Check to see if #1 that plastic film is clean and #2 That the Film is not bent and created a crease which is the line that shows when try to print or scan using the ADF. Hope this helps
Posted on Jan 13, 2011
F Victor man
  • 817 Answers
SOURCE: I'm trying to locate the serial number on my
Open the main cover and the head will move into the centre of the carriage.Just to its right face up is a sticker that says serial no: xxxx12345. thats it. I too have a MX410 and its a great little machine.
Posted on May 27, 2011
pgh_pa_guy
  • 2992 Answers
SOURCE: Canon mp 980 won't even copy or scan if any
Sorry, but no. As far as I know that's how all of these all-in-ones work. If the printer doesn't work because the cartridges run dry, nothing else works either. They don't allow you to use the scanner as a standalone piece.
Posted on Jul 06, 2011
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
My mx410 is leaving lines on everything I scan copy or print
clean the flat glass as well as the scan glass
Oct 22, 2013 | Canon PIXMA MX410
Whenever I scan a picture, It's blurry. Canon Mx410
I had the same problem.
My DPI setting was at 25.
I upped it to 600 and the document scanned perfectly.
Jun 04, 2013 | Canon Pixma MX410 All-In-One Printer
Changed cartridge and now won't print a document
Verify the data cable or the PC printer setting,perform the test page,if you make a copy not problem the cartridge change.
Feb 25, 2013 | Canon Pixma MX410 All-In-One Printer
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
Just trying to make some copies...the display on the printer says
The ADF is the "automatic Document Feeder" it thinks something is in there when there isn't. check to see if something is stuck in it that would cause it to "think" that.
Jun 24, 2012 | Canon Pixma MX410 All-In-One Printer
Document in ADF
None of these worked for me. Here is my FIX:
Open the part containing the rollers. You can see a white plastic part which stop the documents feeded into the adf. Lower this part and insert a page into the adf just a bit further than where it would have stopped from that white stopper. This forces the machine to feed the document and clears the error right away. You only have to do this once and from then mine worked fine.
Jan 25, 2012 | Canon Pixma MX410 All-In-One Printer
I want to scan documents using the ADF, but I got a message on the LCD saying "Cannot scan from ADF". This shouldn't be the case since it's advertised on the box of my Canon PIXMA MX410...
Funny. Actually, very funny. Why? Because it seems that my previous printer was fully functional, but i got a new and better one from Canon, because it had this problem, which seems to be just a false error. The error should say "Please select the paper size to scan from ADF". That's how i just fixed the problem when it appeared on this new device as well.
So the solution (at least for me) is to manually select the paper size to be scanned.
Sep 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Why is there a line on the left side of my copy when I use the ADF on my Canon Image Clas D1150? It does not do it when the flatbed is used. Please help. Thanks, Joann
When lines appear on copies of documents fed through the ADF, it typically means that there is some kind of dirt or foreign material on the glass that the document passes over. A different window is used when scanning from the ADF as opposed to the flatbed. The flatbed window is large, often much larger than a standard sheet of paper. The ADF window, on the other hand, is small and slender. It doesn't need to be large because the document moves over it (as opposed to the flatbed, where the document is stationary while the scanner moves under it).
The ADF window is usually situated next to the flatbed glass on the side of the scanner where the ADF takes in the paper. Open the scanner lid (as though you were going to make a copy on the flatbed) and find the slender piece of glass just under where the ADF would be when the lid is closed. Once you've located the ADF glass, use a mild glass cleaner and a lint-free cloth to gently clean the surface of the glass. If you are able to see the foreign material, you can remove it by hand, but be sure to clean the glass thoroughly afterwards, as fingerprints can also cause poor quality copies.
After the glass has been cleaned, test the ADF copy function and make sure the line has disappeared. If it has not, you may need to remove the slender glass and clean the underside (though this is almost never required, as the underside is protected from environmental debris).
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Canon imageCLASS D1150 All-In-One Laser...
Canon Pixma MX410 All-In-One Printer Logo
1,514 people viewed this question
old marine
old marine
