Dead usb ports
I have a new Gateway desktop with four USB ports on the back, a pair on the front bottom, and another mid-front. One of the back four is dead, as if one of the front pair. How can I fix this?
Thanks.
    Problem Solver:
  • 18 Answers
If it's new, get it fixed under warranty. A dead single port of a pair indicates hardware fault
Posted on Oct 24, 2008
WHERE IN THE BACK OF MY GM5072 DO I PLUG IN MY SPEAKERS?
  • Rear External
    • Four USB
    • Two PS/2 (keyboard and mouse)
    • One Parallel
    • One Serial
    • One VGA
    • Six Analog Audio jacks
    • RJ-45 LAN
  • Front External
    • Three USB (one in media manager, two on front ports panel)
    • Two IEEE 1394a 6-pin
    • Two audio 1/8-inch mini-jacks
      • Headphone (green)
      • Microphone (red)
  • Nov 14, 2012 | Gateway GM5072 Desktop PC
    Need a wiring diagram for a rs780m03g1
    http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
    1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
    2) Product Views;
    http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
    B - Processor Core Power Connector;
    is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
    Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
    General example of connector, and power cable,
    http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
    2) D - CPU Fan Connector,
    The Processor fan connector is white in color, 3-pin, and above the processor socket.
    3) F - Main Power Connector,
    The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
    4) N - Front Audio Connector, (Front Panel audio ports)
    Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
    5) P - System Fan Connector, (System Fan = Computer case fan)
    White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
    6) Q - IEEE 1394 Connector,
    For the front panel Firewire (1394) ports.
    Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
    7) R - USB Connectors, ( Front Panel USB ports )
    F_USB 1 through F_USB4.
    Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
    8) S - Front Panel Connector,
    located at Bottom/Right corner of motherboard.
    Pin 9 is N/C also.
    Not Connected. Used for +5 Volt power for the factory.
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    Oct 27, 2012 | Gateway E-4300 PC Desktop
    Gateway 5632E usb high speed ports locations
    You can view the rear I/O panel of the GM5632E (including six USB 2.0 ports) atGateway Support - Ports.
    The front view, including two USB 2.0 ports is atGateway Support - Front View.
    May 02, 2012 | Gateway Computers & Internet
    Wher are the USB ports on Advent DT1308
    Advent Advance DT1308 Desktop PC?
    http://www.pcpro.co.uk/reviews/desktops/370084/advent-dt1308
    Look at the Back of your Advent computer tower.
    Look at the lower left.
    This rectangular area is the I/O area.
    Input/Output area.
    This is where Input and Output devices are attached.
    Look at the Purple round PS/2 port all the way at the right bottom.
    It's where the Keyboard plugs in.
    Right above it are four USB ports.
    http://en.wikipedia.org/wiki/USB
    There are several styles of USB ports. This style is a USB female type A,
    http://en.wikipedia.org/wiki/File:USB.svg
    (Standard A )
    According to the review (Specs tab), there is supposed to be two USB ports in the Front. (Front Panel)
    I do not see them.
    Could be behind a door that swings open.
    Looking at the Side View, with the Side Panel of the computer case removed, the USB cables going to these front ports, are going towards the bottom/front.
    Regards,
    joecoolvette
    Apr 25, 2012 | Computers & Internet
    Where do you hookup the printer to the one zx series
    Where you hookup your printer to your PC will depend in part on what interface your printer uses to communicate with your PC.
    Some of the possibilities are the parallel port, the USB port or a lan port.
    Most printers these days use the USB port.
    There appears to be four USB ports on the back of your machine.
    HTH
    Jun 16, 2011 | Gateway One ZX190 PC Desktop
    Front usb ports are dead
    If you have tried to use a known good device on both front and back USB ports with the same results. The front USB board will need to be replace.
    Contact Apple Support 1-800-275-2273
    Jan 18, 2011 | Apple MB871LL/A Mac Desktop
    I have a gateway zx4800-03 and I need to know how to remove the hard drive to put in a new one
    I removed one on a Gateway ZX4800-02. Remove two screws by the usb ports on the back. then remove the plastic piece covering the usb ports on the back. This will expose the HDD. Now to make it easier. remove the four screws holding the support bracket and remove support bracket. remove the three screws holding the HDD located up, right, and left. Now disconnect the HDD cable by pull it to the right by the connector. DO NOT PULL THE CABLES. My friend does that by habit all the time and it drives me crazy.
    HDD should come out easy. Just remove the metal cage covering the HDD and Replace. Reverse order for reassembly.
    Now does anyone know how to get off the damn front bezel!>!!?!?!?!? I can't figure it out.
    Dec 08, 2010 | Computers & Internet
    Does my dell dimension 2350 have a dvi port?
    No, it does not.
    Check the specs of your desktop PC here:
    Ports and Connectors
    Externally accessible:
    Serial
    9-pin connector; 16550C-compatible
    Parallel
    25-hole connector (bidirectional)
    Video
    15-hole connector
    Keyboard
    6-pin mini-DIN connector
    Mouse
    USB
    two front-panel and four back-panel USB 2.0–compliant connectors
    Network
    RJ-45 connector
    Audio
    three back miniature connectors for line-in, line-out, and microphone
    Headphone
    one front miniature connector for line-out
    Serial
    Parallel
    Video
    15-hole connector
    Keyboard
    Mouse
    USB
    Network
    RJ-45 connector
    Audio
    Headphone
    http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
    Jul 26, 2009 | Dell Dimension 2350 PC Desktop
    All USB ports dead....
    Try removing the PCI USB Adaptor and clean the gold contact with dry brush, then place it back again. If this still doesn't work, try moving the PCI USB Adaptor into other available PCI slot.
    I hope this procedure solves your problem.
    -mrsolution
    Jun 11, 2008 | Gateway GT5228 PC Desktop
    Usb ports not picking up memory stick
    Is it just Memory Stick, or everything that you plug into USB?
    Try following:
    1. plug in other USB device into ports
    2. if it does not detect any USB device on any port on your computer
    3. if both front and back USB do not work it may be taht USB is turned off in BIOS, or USB driver is corupted
    4. If you have front USBs and they just do not work there is wire connecting them to the motherboard since it may be loose, if connection is OK than they are dead.
    5. If just back USB do not work than they are dead>
    Jan 30, 2008 | Computers & Internet
    Computers & Internet Logo
    50 people viewed this question
    David Payne
    David Payne
