Question about Vacuums
Cant find my manual. Need to install a new belt. Rose
  • Anonymous Jan 19, 2009
    Ihave a hoover elite upright and I need to change the belt . Ilost my manual
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Please post the make and model of the vacuum.
Have no manual, hwo do I change the belt on a Singer Mocel # 3510-4?
Posted on Oct 25, 2008
Where can I obtain a FREE Manual for my New Home Simplicity Sewing Machine model #446? Thank You, Rose Harris roseharris2008@yahoo.com
Try posting the machine number and name on the internet and google it, you may get it there or just go to a store that sells this machine and ask them if you can photocopy the manual.
Apr 25, 2011 | Vacuums
It sucks but the roller doesnt turn...I think my motor has burned out?are these vacuums made anymore? I also need the manual for the model 116 35913401 thanks
this is not a motor problem this sounds like a broken belt. Take the model and make # to your local used vac store and they can help you with the belt. If you dont or cant install it yourself bring the whole maching to them and they will do it for next to nothing.
Oct 07, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Change fanbelt
Here is a link to the belt you need and a manual you can view which shows you how to change a Dyson DC07 Belt.
Dyson DC07 Belt and Manual
Dec 04, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum has burning smell like a belt but cant figure out how to tear apart
First job is unscrew the 3 retainers (arrowed) they turn a quarter turn.
If your belt hasn't snapped it will need pulling off the motor shaft
The brushbar can now be pulled out (this brushroll had a groove scored into the side of it caused by a hair grip its visible just to the left of my thumb)
With the new belt positioned on the new brushroll insert it into the hole and locate brushroll
(To make the belt easier to locate on the motor shaft give it a bit of a stretch)
Ensure these lugs are located correctly
Pull the belt over the motor shaft
Refit the soleplate cover and tighten three screws
Before switching the machine back on rotate the brushroll to make sure the belt hasn't been trapped between the soleplate.
I hope this helps and good luck!
Nov 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
No manual
Take the hood off of the unit, and remove the brush roller and belt. Wrap the new belt around the shaft of the motor and slide the brush roller inside the loop of the belt. Use the brush roller as leverage to stretch the belt out and slide the brush roller back into the roller housing. Once you have it installed correctly, make sure the roller and belt are free, by spinning it by hand. If that belt is pinched it will just burn it up when you turn the unit on.
Good luck
Oct 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Belt replacement
Hi.
You are correct there are 2 belts.
They can be tricky to replace most shops will state they cant be replaced & you require new clutch.
So try this site http://dysonmanuals.llc.nu/ for manuals on how to remove clutch unit & replace both belts they are very good with lots of high quality pics.
Chris..
Jan 26, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
New Eureka vacuum cleaner belt keeps slipping off
You may have a bad brush roll, part #61250-1, or the base itself has a problem and isn't letting the brush roll sit straight so it can be in alignment.
Jan 07, 2008 | Vacuums
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
