Question about Samsung Office Equipment & Supplies
Computer says paper jammed but i can't see or notice paper jammed.
ML 1670 - computer says paper jammed but no paper is jammed
    Problem Solver:
  • 6 Answers
I have the exact same problem! Think it started after installing Windows 8. I have installed other firmware onto the printer previously to use refilled cartridges. Have you fixed this problem yet, please post a solution if you have one.
Posted on Mar 03, 2013
Inkworks
  • 87 Answers
SOURCE: Paper Jam
Sometimes the "paper jam" with no paper is due to the printer not being able to feed paper in to the machine. You send a print job to it...printer attempts to feed paper but can't...then you get the paper jam message and ofcourse there is no paper in the machine. Powering off and on should clear the message. Make sure you clear the print job from the print que or the same thing will happen on power off/power on because the computer will still try to send the print job to the printer when turned on. I have found that all of HP's machines that have this style of paper feed mechanism fails prematurely. The pickup roller is too small for one but as soon as the roller is coated with dust it begins to fail. You can take a Q-tip and go in from the back to try and clean the roller. Water is fine.
Inkworks
866-381-0541
Posted on Nov 06, 2008
djdevd
  • 67 Answers
SOURCE: paper jammed notice appearing ,but there is no sign of any paper jammed
Power up printer ,then press & hold the (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
Posted on May 13, 2009
  • 240 Answers
SOURCE: Paper jams in Samsung, ML - 1451N
try to arrange the paper properly..
Posted on May 14, 2009
SOURCE: Samsung ML-2510 printer paper jam
This happened to me after I had cleared a paper jam. I finally had to take off the back and cover to discover that there was, indeed, a small piece of paper invisible otherwise (torn off of the paper I removed). I removed the piece with tweezers and now it's working fine. Remove all other moveable parts inside. The top front is held on with two plastic posts + screws, the back by four deep-set Phillips screws. Might work best to remove back screws, then front, then top. The top feels fixed, but it snaps out (sounds loud!) with some pressure, and snaps back in on reverse. Harder to replace than take off.. Be sure the light color on the top on either side of the fuser opening slides under the darker color part of the back (about an inch?) before snapping or screwing it all back. Good luck!
Posted on Jan 12, 2010
markzbylut
  • 64 Answers
SOURCE: After freeing a paper jam on my Samsung ML 1750 the On line/error
Frequently a very small scrap of paper is caught in the paper path. Take out all the trays and the toner cartridge. Then look very carefully with a flashlight for the smallest scrap left behind.
Posted on May 12, 2010
Paper jammed inside my printer near bottom
open front cover where toner cart is situated and remove cart.check and see if the jammed paper has fed into the machine and if so pull paper in the direction it is feeding into the machine.
Oct 26, 2012 | Samsung ML-3051N Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
Get a "paper jam 2"
Ya, in this case you will have to disconnect the printer from the computer, uninstall the drivers from the computer and restart. Then reinstall the drivers and connect the printer back when it asks you to .
Thanks. If this was helpful, then kindly rate me.
Nov 01, 2010 | Samsung ML 2151N Laser Printer
Online error light nothing prints
I have a ML 1710 .Not my area of expertise but I took out the paper and could not see a jam. Took toner out , a little cleaning, plugged and unplugged from computer several times. I found paper jammed in the very back ,folded so tight nothing was showing. Mine has a back door and the paper is having trouble rounding the last bend and coming out. So I leave the back door open to get my copies. Green light on.
Feb 26, 2010 | Samsung ML 2010 Laser Printer
Samsung ml-1640 giving red light, not taking papers
I had the same problem when a paper jammed and I have pulled it out. The red light came on and nothing worked. My solution was: I pulled out the tonner and put it back, opened all covers and closed it. All this apparently must be done with printed turned on (the same thing with printer turned off didn't work). Hope this helps.
Mindaugas
Oct 08, 2009 | Samsung ML-1640 Monochrome Laser Printer
May 14, 2009 | Samsung ML 1451N Laser Printer
Paperjam on fp 1670
maybe your printer has dust or dirt inside.... or something that can make your printer jam... try to clean first your printer.... ^^
Dec 12, 2008 | Computers & Internet
Paper jammed
Your fuser is bad. The fuser is a part that "fuses" the toner with heat and pressure to the paper. You will have to have a new fuser to fix your problem.
Jun 23, 2008 | Samsung ML-2510 Laser Printer
77 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
