Question about Tatung L17AMTN 17" Flat Panel LCD Monitor
Monitor blinks in and out.
My monitor is fairly new. The screen started blinking in and out. I have disconected it and am using another monitor which works fine.
  • XJ Dean Jan 12, 2009
    i have the same problem it will work fine for approximately 15 - 20 minutes then its powers down and the stand by light blinks....anyone help please and thanks
Led bilinking
green LED blinking but no display, when disconect VGA cable from CPU than monitor displays cable disconected. CPU vedio card is ok
Jan 08, 2011 | Samsung 793S 17" CRT Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Problem with monitor (blinks)
it sounds like the lcd inverter board may have gone bad- its what powers the back light on the monitor similar to a flourescent light. usually its fairly cheap to replace (around 25 used on ebay) typically its located inside the lcd bezel on the bottom center.
Nov 01, 2009 | HP Pavilion dv4000 Notebook
When i turn on the monitor, the screen will not stay on...it continuously blinks and blinks and blinks. I tried turning the monitor on and off but it does not work. Any solutions??
monitor could be going bad. plug in the same computer and cable to another monitor. see what you get. same problem? use a new cable on either/both monitors see what happens. this will help you determine if the problem is in the monitor, cable or computer's video output.
Aug 30, 2009 | Computers & Internet
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor blinks
your monitor haveing power supply problume it is not swtiching properly
ashok
Jan 21, 2008 | HP Compaq FP5315 15" LCD Monitor
Tatung L17AMTN 17" Flat Panel LCD Monitor Logo
90 people viewed this question
Top Tatung Computers & Internet Experts
Alun Cox
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
