Question about IBM Wheelwriter 30 Typewriter
Carriage sticks about every third time the carraige returns it sticks.
    Scholar:
  • 183 Answers
Clean and oil the rails the print head slides on, and oil transport motor shaft at both sides of motor. you don't have to take the case off, you can see the motor by lifting up the paper table and looking on the right of the platen, and you can see the back of the motor through the paper release lever slot
Posted on Oct 24, 2008
We were trying to locate problem wih sticking carraige when the document feeder was lifted to far and the left side hing sprung so that the cover would not close fully. Is this repairable. I am sure the...
When carriage mechanism fails it need to be repair by a technician.Most carriages systems fail due to bad internal parts,most common the belt that move the carriage.
Mar 01, 2011 | HP OfficeJet 5505 InkJet Printer
My Sears electric typewriter "scholar w/
could be the carraige release button on the carraige is stuck down (pull it back up). Otherwise the mach. is stuck in "tab" mode or the escapement (the mechanism that hold the carraige in place and lets it advance 1 space at a time) is FUBAR'ed, in eithor case it would need professional help.
Dec 28, 2010 | Smith Corona Office Equipment & Supplies
My royal typewriter i just purchased on line its from the 50s and is blue has a carraige return problem. the carraige always stays to the left so you can not type you push it back and it just flys right...
The starwheel/escapement is probably gummed up. If you look from the bottom, you should see a "star" shaped part. Carefully spray a light lub around the area and move the carriage back and forth to free it. It may take several attempts.
Dec 20, 2010 | Royal Office Equipment & Supplies
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Southern Comfort Carraiges and Sugar Creek Horse Drawn Carriages
I looked at the website & didn't see your address, but maybe Jesus gave it to him. Seems that's how he got everything else.
Nov 18, 2009 | Computers & Internet
When we get to the end of the 1st page, a 2nd page doesn't show
Novice Ron:
Try using the Word button that looks like a capital "P" in reverse. It should be on the top of your Word window. This will show you some of the hidden information in your WORD document. Many times, pages will skip when "Page Break's" are inserted or when there are too many carriage returns in the doc. These carraige returns look pretty much like the Word button referred to above. Place your cursor on any one of these and delete them until you get rid of the extra blank pages.
Mar 16, 2009 | Microsoft Word 98 Macintosh Edition...
Printer Cartridge Carriage Stalls
the settings of the gears is misalligned.a technician at your place is advisable as this is a very important part of the printer if any of the arm breaks the printer may face major problems.still stick that arm with a cellow tape on it firmly and then give a print out.if the page prints properly that means it got adjusted automatically.
Oct 18, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carraige return pull came off
I'm assuming you mean the strip of translucent plastic on which the carriage runs. I was able to reattach mine - it requires small hands and a flashlight, as well as some patience!
The punched-out holes at each end of the strip have to be correctly aligned to fit into the metal prongs (I found the left side to be most difficult). It took me four or so tries and about twenty minutes.
May 03, 2008 | HP PSC 750 All-In-One InkJet Printer
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
IBM Wheelwriter 30 Typewriter Logo
63 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
