Question about Panasonic VDR-M75 DVD Camcorder
LCD screen white
Hi, when I open my lcd screen, the screen appears all white with some lines running through it. The camera records and takes pictures fine. Also, when I look through the viewfinder, it flickers. Thank you for your time.
SOURCE: LCD no image
it is same with my camera same type also.the problem is from flexible cable from mainboard to lcd .same of the core is break..until now i can'ot get that cable.
you just buy the cable and on your camera and ok.
if you have information abaut that cable please submit to me
Posted on Oct 22, 2007
SOURCE: LCD Screen goes blank after opening up
You will have to replace or get replaced the LCD hinge unit.The connector strip brakes after several intervals of opening and closing LCD Panel.
Posted on Oct 28, 2007
SOURCE: Problem Supercam AG-Dp 800heg
Hello Situ,
If you must Change the erasing head's supply filter (capaciter) then change the audio erasing Bios OSC, transformer supply filter tantlem capaciter, the problem will be clear.
Posted on Jan 04, 2008
  • 15 Answers
SOURCE: Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
Posted on Jan 14, 2009
  • 172 Answers
SOURCE: White LCD screen on panasonic PV-GS320
LCD cable is damage so that lcd is white it need to replace
Posted on Mar 02, 2010
  • 4234 Answers
SOURCE: Hi, I have the Panasonic
The problem is likely to be the flat ribbin cable that goes from the camera body to the screen. It has developed a crack in one or more of the wires. The cable will need to be replaced. This is a tricky operation as the dis-assembly of a camera is not simple. I would recommend that you take this to an authorized Panasonic service center for repair.
Posted on Aug 25, 2010
0 characters
1 Points
Problem is that when we open the camera white screen display on lcd ,no pictures display but movie recording is ok.
Connecting flexible cable between lcd board and main board of camcorder seems lose, open lcd cabinet and insert flexible cable in connector of lcd board properly to get image in lcd screen.
Below image shows flexible wire and connector on lcd board of MHS-CM1 camera.
Hope these info will help you.
Nov 17, 2010 | Sony MHS-CM1 HD AVC Camcorder
Lcd screen lines in sony handycam dcrsr45. when i start camcorder there is vibration type lines in lcd screen,not white lines just picture and horizontal vibrations which are recorded in was...
The most common problem with this camcorder is the lcd cable assy. It is the cable that comes in from the lcd panel assy to the internal board assy. I have seen possibly 100 of these cameras and different models and this fixes it everytime.
I hope this helps.
Sep 05, 2010 | Sony Handycam® DCRSR45 HDD Camcorder
My samsung mini camcorder scd103 screen and veiw finder is white. i can't record picture but i can record sound.
Hi,this sounds as if the LCD monitor is defect and will be in need of replacement.To confirm LCD defect,insure that problem is with display, by verifying video output to TV or PC.If video is alright through a/v outputs to TV,than LCD is defect.However,if TV output is also white,than problem lies on main camera PC board.Whichever the case I do think that warranty repair should apply on this model and suggest to contact mfg factory service.
Note - In few cases i have seen that even corrupted firmware could cause the same.
Good Luck!!
Aug 19, 2010 | Samsung SC-D103 Mini DV Digital Camcorder
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung scd103 mini dv ( white lcd screen)
Go to for more information
Mar 03, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
My LCD Screen..
Your flat-wire connection between LCD monitor and the monitor PWB inside the camera is broken. can't fix it by yourself. Look for a Panasonic authorized service only!
Sep 20, 2007 | Panasonic PV-GS31 Mini DV Digital...
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Panasonic VDR-M75 DVD Camcorder Logo
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
