Question about Midland 26-Mile, 22-Channel FRS/GMRS 2-Way Radios with Charger (Pair) - Black/Camo
Midland two way lxt380/385/xt27/28/30 wont stop Rx is showing but nobodies Tx it?
Came in a two pack one works perfect , but the other one is receiving transmission and when you try to Tx the two way from the other , it comes in real faint.
5 Suggested Answers
  • 157 Answers
SOURCE: midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Posted on Nov 07, 2008
n9vsj
  • 18 Answers
SOURCE: Midland LXT 300
they could be set to the wrong tone or channel.
Posted on Apr 14, 2009
Dodgem250
  • 68 Answers
SOURCE: midland 77-250k No RX nothing, TX perfect on
Best course of action is to ship it in. www.Dodgem250.com
Posted on Apr 12, 2010
SOURCE: Hi, I have a LXT380/385. I find out haw to turn
I had the same issue here is the quote from the owners manual: To increase/decrease the volume level, press the up or down button during RX or STANDBY mode. With both radios on the same channel hold down the transmit or "PTT" button--this will put the other radio in the RX mode. While holding down this PTT or side button on one radio then you can adjust the volume on the other radio using the up or down arrows. (This is how you do it on RX mode. I'm not sure yet how to enter Standby mode.)
Posted on Dec 26, 2010
I have a midland 1001lwx 40 channel cb and unless I'm next to anpther vehicle ( parked side by side) there is no signal getting out. I know it isn't the antenna , checked with second radio
Check the SWR. also those style radios have small vertical boards.. in them and they come loose from the main board and wont TX or RX when that happens..
Nov 21, 2015 | Midland Radio Communications
Need a manual for a Midland XT-26 two way radio. Need to know what battery pack and desktop charger it uses.
Go to Google search Type Midland Tx-26 Owners manual. It should offer it to you.Sometimes it wants you to pay for it, some free. Look at Amazon.com or Ebay also for help.
Mar 31, 2011 | Midland XT511 Two Way Radio
Put another **** on 29 ltd and lost key up and receive but it still lights up. What you thank is wrong. 5 different mics, all work in my other radios. I heard something chatter and it would not tx or rx...
Check to make sure that there is noting shorting out inside of the radio. some mic plugs can turn from overtighting the mic connector.. also check the pins they may be broke or compressed too much and won't make connection to any mic.. Pin 1 is ground and pin 4 is rx.. take a jumper wire across those and see if you get rx back. same for tx pin 3.. jumper pin 1 and 3 should have a key up. pin 2 is your of course audio. these should be first things to check. cobras unidens and galaxys, connex, genlee etc. are wired the same. midlands and radioshacks ge are different. so make sure your mic is wired for a cobra or galaxy also.. any mic will work on any radio. as long as is it wired to it correctly....
Dec 15, 2010 | Radio Communications
Midland 5001 40 channel cb radio all is fine with the radio except I question one thing there is a chirp that occurs just before the key down it chirps first then keys up and talks fine. Is this something...
Hi Tom
Ya know I have that same radio with the same chirp. I have asked many to tell me if they hear the chirp on the air and no one has heard it but me. I know what it is but i wont fix it due to the fact it is the only radio that does that to me and i think its kinda cute for it to do it. Now to let you in on the secret is that for the radio to go from rx to tx is handled by transistors plus the computer has to give final say so to tx. So the chirp is developed by the switching and computer turn around times to allow you to talk. I hope this helps.
Ray
Jun 13, 2010 | Midland 5001 40-Channels Base CB Radio
Midland 77-250k No RX nothing, TX perfect on
Apr 10, 2010 | Midland 77-250CXL 40-Channels Base CB...
Tx and rx
can you clarifiy? please
Oct 25, 2009 | Midland 4001 40-Channels Base CB Radio
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Midland LXT 300
Apr 08, 2009 | Midland LXT303-A 2-Way Radio
Midland 26-Mile, 22-Channel FRS/GMRS 2-Way Radios with Charger (Pair) - Black/Camo Logo
93 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
