Question about Sanyo DS31520 31" TV
TV shuts off after few minutes
I have a 63' Toshiba Flat screen TV about 6 years old. A few weeks ago when I tried to use it, after only a few minutes the TV turned off abruptly. The red light next to the power button began to flash. If unplugged and plugged back in, the TV turns on and off again after a few minutes. I moved it to a different outlet and it worked fine for a couple weeks. However, when I just now tried to turn it on, it does the same thing. Any ideas?
Tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Posted on Nov 02, 2007
SOURCE:
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Le2412 power on problem
The power supply is failing.
Dec 20, 2013 | Apex Digital LD4088 LCD TV
62MX195 screen goes momentarily black a few times per minute
may or may not be lamp: lamp has a average life of 2,000 hours which is about 2 years for most people.
Apr 18, 2012 | Toshiba 62MX195 62" HDTV
Hi! My toshiba 2100td tv is over 10 years old and last few years it's having weird problems. When it's turned completely off (not in standby) and when I turn it on, the screen blinks for a 10-
The real problem here is its age, a lot of these sets of that age critically needed parts are just no longer available.
I repair them but the real risk is someone fixed it, a few months later it develops another problem etc etc etc.
Ten years is now a days a long life for a TV.
Apr 16, 2012 | Televison & Video
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
TV abruptly lost picture still has sound,less than
change your scart lead or even just make sure its connected propperly have a look at the pins in the scart and make sure none are bent or missing
Mar 04, 2010 | Toshiba Televison & Video
Toshiba 32" Model# 32A33 TV About 5 years old
change tact switches
you have windex syndrom
using too much windex cleaning tube
Aug 26, 2009 | Toshiba 32A33 32" TV
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
Ok, so know you own an LCD or Plazma set, visit the dumpster where your Toshiba is or perhaps your basement just for old times sake..
May 30, 2009 | Toshiba 32D46 32" TV
Sanyo DS31520 31" TV Logo
324 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
