Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load Washing Machine
I had a large load of towelsd washing. It made a really loud tumbling noise and stopped operating. It has not operated since. It will power on and try to start but then the lights go back to the final rinse stage and it justsits there.
Suggestions?
I had the same problem. When it was out of balance the motor struck the motor control module mounted in the back left of the washer, damaging it. I have ordered a replacement and awaiting the part to repair.
Posted on Oct 29, 2008
Yes...it spins free like it is independent of the motor. I did take the back off and the belt is still attached properly though....... Please advise.
    Novelist:
    Champion:
  • 261 Answers
Does the steel basket wobble when pushed by hand? Does it spin really free like it is independent of the motor? Let me know!
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader makes banging noises in spin cycle
hi there.......if this problem has just recently appeared...its quite possible that 1 of the tub suspension springs has broken resulting in the tub lying at an angle and causing this unbalance....you can check this by tilting the machine and looking at the tub susension points
regards Sir Galahad
Aug 16, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
63 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
