Sky remote code for sanyo ce32ld17-b
SOURCE: Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
SOURCE: I need a code for
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
SOURCE: MY SANYO TV WONT EXCEPT
some of the older sky remotes do not have the codes for newer tvs.
i had the same problem myself,
if there is NO sticker inside the battery compartment, then the remote is probably earlier than version 4 and you will probably need to buy a new remote.
