Question about Qca Spas Pool & Spa
QCA majestic plus spa problems
Keeps shutting off after an hour or so...
    Top Expert:
  • Qca Spas Master
  • 8,163 Answers
Bad motor overheating
Posted on Oct 03, 2017
4 Suggested Answers
  • 990 Answers
SOURCE: hello! the pump on our qca majestic hot tub
If you live in cold weather and are not using it much lower your thermostat. If the freeze control kicks on (at about 38-40degrees) it will constantly try to heat the spa to where you have the heat set when the air temp is low. Hope this helps.
Posted on Oct 31, 2009
  • 366 Answers
SOURCE: I have a qca jewel plus spa and the diagnostic
you should be able to locate the pressure switch near the pump, most likely on the discharge side. Before you replace the flow switch, make sure your filters are clean and there is not an air lock on the system. The flow switch is fairly easy to replace. You'll probably have to drain the spa unless you have blade valves to isolate the equipment. With the supply power off, you can remove the front panel on the spa pack and find where the flow switch is and disconnect it. You can then replace the flow switch. Make sure the new switch directional arrow is facing the right direction so it will read flow properly.
Posted on Jan 18, 2010
Testimonial: "Thank you this is very helpful"
Ian  Hot Tub
  • 77 Answers
SOURCE: Qca Spa pumps and blower will not come on, water down to 35º f
Ken,
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
Aruba spa model1060
bad motor or if it pops breaker disconnect the heater leads remember where they go try it again if it runs bad heater element
Aug 08, 2014 | Qca Spas Majestic Series Aruba Xl Hot Tub
HAVE A 2001 STANDARD SERIES POWER TO SPA BUT NOTHING COMES ON
I was just wondering if anyone knows how much water the QCA Majestic Spa holds ???? It doesn't tell you in the directions!
Sep 06, 2012 | Qca Spas Dream Series Dream Master Hot Tub...
Every time the pumps shut off I get a FLO code. Where do I find the flow switch
That is just telling you that your heater isn't working because you don't have flow. This is because your pump is off.
Nov 26, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
QCA spa pump won't shut off
bad multiple speed relay and temp sensor
Apr 03, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Spa water is overheating and get a HL error code
This is a problem in your board or something is jumping the safety circut. You should have someone look at this to be sure that no other problems have come from this. Good luck.
Dec 18, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Looking for older manual for8 button qac majestic spa cntrol can you tell me were to get this
This is the only one available online.
http://www.qcaspas.com/content/pdf/Majestic-10Btn.pdf
Nov 15, 2009 | Qca Spas GT 454 Hot Tub
Hello! the pump on our qca majestic hot tub
Oct 28, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Filter for QCA Aruba xl
QCA has used 4 different sized filters in their tubs through the years.
  • c-4326 4-15/16" x 13-15/16" 25 sq ft
  • c-4950 4-15/16" x 13-15/16" 50 sq ft
  • c-4995 4-15/16" x 23-5/8" 95 sq ft
  • c-5397 5-5/16" x 17-13/16" 80 sq ft
you will need to measure the inside height and diameter of housing and see which one will fit best.
Jan 30, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
