Question about Candy Washing Machines
Where do i buy candy go682 80 drum bearings
Go682 80 drum bearings
To the best of my knowledge (I have attempted to make the same repair to my own Candy GO682-80) it is not possible to replace the bearings as this machine uses a "sealed tub" design. That is, it is not possible to separate the two halves of the plastic tub because they have been permanently glued together instead of bolted/screwed. This probably explains why nowhere seems to sell a bearing kit for this model.
Posted on Jul 07, 2013
  • Peter Duerden Jul 07, 2013
4 Suggested Answers
  • 249 Answers
SOURCE: Bearing fix
That job is for a very skilled person I would not take it on unless you are that person,by the way it comes in a kit TWO bearings and water shaft seal I would replace drum shaft as well Eamonn Ireland
Posted on Jun 12, 2008
  • 38 Answers
SOURCE: candy drum bearing replacement
if you are absolutely sure it is the bearing, you will need a special tool to pull the old one off and press the new one on. My advise is to have a professional repair person do the job.
The Candy front load machines have a three-pronged support at the back for the drum. This sometimes get cracked or broken, when this happens, you will have to replace the entire drum assembly as the support is riveted on to it.
The broken support causes the inner drum to rub against the outer tub, giving the impression that the bearing is bad.
Posted on Jun 15, 2008
SOURCE: how do I remove drum
How do I remove bearing from Candy CNW136 washer/dryer.
Thanks
Reply to rsparling@manutec.ie
Posted on Feb 15, 2011
How do the drum caseing come apart to change bearing on my candy go1482 washing machine
Candy GO1482 model is made by Hoover and the drum is welded shut. You can't replace the bearings (cost usually 10 GBP) and a replacement is 220 GBP plus vat. I've just been bitten and hurt badly over it. Next time buy Indesit, Hotpoint or Bosch.
Aug 10, 2011 | Washing Machines
How do I remove drum bearing from Candy CNW136 WASHER / DRYER
Thanks
Jan 20, 2011 | Candy AQW130 Front Load Washer / Dryer
Hi, I have a candy Grand O GO1682 washing machine and on spin it is making a very loud rumbling noise, So i am assuming this is the drum bearing, But What is the part number, is there more than one, and is...
I HAVE THE SAME PROBLEM, AND A ENGINEER SAID THAT THE BEARINGS HAVE GONE AND THAT IT TAKES 2 PEOPLE TO FIX IT AND THAT THE BEARINGS 7 DRUM COME AS ONE COMPLETE SYSTEM AND WILL ROUGHLY COST ABOUT £200 AND TAKE ABOUT 2 HRS TO FIX. SO IS IT WORTH IT OR BUY ANOTHER ONE INSTEAD.
Oct 13, 2010 | Candy CN136 Front Load Washer
Drum bearing noisy on spin
Remove the drum drive belt, and spin the drum by hand.
If it is noisy, or feels rough, then the main drum bearings have failed.
This a major repair.
Hope this helps.
Dec 15, 2009 | Candy Washing Machines
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Detergent build up
try to wash clothes with pre-wash program
Feb 17, 2009 | Candy CN146 Front Load Washer
Bearing fix
Jun 12, 2008 | Candy CNW156 Front Load Washer / Dryer
Candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Jun 12, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
May 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Washing Machines Logo
66 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
