Display is blank
HP Pavillion tx1000 blank display, (black) nothing.
Also I hear no beep when starting up but I can hear fans running.
  • 5,568 Answers
This may not be the monitor's fault, it should flash a front panel LED when power is applied and most monitors will now flash a message if they are healthy but have no input signal.  Watch if your keyboard lights flash at power on and then the hard drive light on the system box to see if the computer is even booting.
If the system seems dead, you may have to open the case (only a few screws hold one side) and, with the power off, ground yourself on any bare metal you see and then pop the memory boards loose and then reseat them, trace each plug from the power supply (normally a silver box into which the AC is plugged in the back) to its end and if connected, disconnect and then reseat the plug.
If you have an accumulation of dust bunnies, blow them out and if any fans are carrying a bunch of dust, use a clean paint brush to free the blades a bit. I don't recommend using a vacuum since they can produce a ton of static charge and that can be death to low-level ICs.
I generally will reconnect everything external to the system box and turn on the power before reattaching the side panel removed for access; that gives you a chance to check if the CPU fan is running and any others that might not be visible once the case is buttoned up.
Good luck-
Posted on Oct 26, 2008
Hp pavillion dv2700 is not starting, 3 beeps, 1 long and 2 short
That is some sort of video failure. "Unable to initialize video (to display the post code)"
Dec 31, 2013 | HP Pavilion dv2000t Notebook
Hi! My Hp Pavillion a1710n desktop emits a series of never ending beeps every time I turn it on, and nothing appears on the monitor. I checked and the monitor is plugged in. I dont know what's going on.
The problem with RAM or DISplay card(It can be Moisture problem) or Processor Fan is not working properly. Open the CPU case, locate RAM, remove the ram by opening the both side clips. and put the RAM back as it is. If you have Graphics card on your CPU then remove the Graphics Card also and put it back as it is. Start the PC with opened case to check Processor Fan is Rotating or not. If Fan is not working properly then you have to replace the Processor FAN. Fan ok but same problem persists. you have to replace RAM with new one. as well as Graphics (Display) card.
Jan 19, 2011 | HP Pavilion A1710N Desktop PC
Can you help me, my laptop is hp pavillion tx 1110ca. the problem is when i turne it on the monitor display nothing all is black, what shall i do?
Are you hearing any beeps when you turn it on, or does it seem that the computer is starting normally but with no picture? If you have another external monitor, try plugging it in using a VGA cable from the laptop to the monitor. If it works, it indicates that the laptop screen or inverter require replacing, if not, the Graphics chip may have died.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | HEWLETT-PACKARD PAVILION TX1110CA LAPTOP...
Blank Screen on start. No display
You need to replace the motherboard. When nothing comes on the display this means the bios on the motherboard is bad and the board and cpu need replaced.
Mar 17, 2010 | HP Pavilion dv2000t Notebook
Pavillion TX 1215 - Blank Display - HP WHY are you cheating.??
Is the techo going to re-solder the video chip to the motherboard and get the laptop going again, or is he recommending a replacement motherboard?
The overheating problem could be causes by a faulty fan (stop spinning or spins slow) and or dust clogging the fan and heatsink assembly.
The cost of repairing or replacing the motherboard may not be worth it and may be better to put the money towards a new laptop.
You can used the old hard disk by putting it into an USB hard drive adapter case and use it as an external USB hard drive.
Jul 22, 2009 | HP Pavilion tx1000z Notebook
What to do when I dont get the LCD display in hp pavillion tx1000
Hi
did you see start up screen if not then just clean your RAM & remove your battery & plug in then try if u face same problem then send me more details
Harry
Jul 15, 2009 | HP Pavilion tx1000z Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
One long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
544 people viewed this question
David Payne
David Payne
