I need the settings for the carb. thx.
SOURCE: Echo Weedeater won't stay running
The one with the filter goes to the carb.,one should come from the tank to the primer bulb and one from there to the carb.
SOURCE: Have an Echo Weedeater GT2000; just cganged the
check fuel hoses for tears as you prime make sure two screws are tight that holds the primer bulb
SOURCE: Primer bulb stays in after depressing it.
sounds as though fuel lines are incorrectly hooked up
Testimonial: "Echo GT 200R Grass Trimmer.Fuel lines were correct.I had purge base gaskets on wrong side of carb.I replaced gaskets but still won't start.Carb cleane"
SOURCE: carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
SOURCE: whats correct gas mixture for
Your owners manual states: 50:1 Echo High performance 2-Stroke Air Cooled Engine Oil
That would be 2.56 ounces of oil to 1 US Gallon of gas.
