Question about Kenmore Sewing Machines
MODEL 385.18836 won't sew in reverse mode?
Won't seew in reverse
SOURCE: reverse on kenmore sewing machine 385
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
Posted on Feb 17, 2008
SewTechWayne
  • 186 Answers
SOURCE: my sewing machine is sewing in reverse Kenmore 385-1960180
Hopefully this is only a mechanical problem that can be fixed with oil. If not it is either a stepper motor or circuit board. If you are not comfortable with removing covers and oiling then it needs to go to the shop.
Posted on Jan 30, 2009
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
radiohead68
SOURCE: serger
As long as this is a sewing machine and not a serger, I don't know about them. I only tinker on my own. Remove the bottom. There is a rod running along the length of the machine. it needs to be turned 180 degrees. You may need to retime the machine.
Posted on May 29, 2009
SOURCE: Singer Model 6212c only sews in reverse...
there's probably nothing wrong with your machine.
check and see if your stitch length setting is set to Stretch instead of somewhere between 2 and 3.
If it's in the stretch zone (below 0), it can sometimes sew backwards unexpectedly depending on what stitch you have selected.
make sure you have selected a straight stitch, and then select the highest stitch width and a stitch length of somewhere between 2 and 3.
it will most likely work fine.
Posted on Apr 02, 2010
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
Sewing machine won't reverse
We need to know if what brand of sewing machine you are using so that we can best suggest. It it is a brother sewing machine like mine then try going to here website. You will have answers on your problems there.
Sep 03, 2012 | Sewing Machines
Reverse lever won't work
take off the top again and take a good look while pushing the reverse lever. See if you can see what the problem is.
Aug 22, 2012 | Toyota Sewing Machines
Won't sew in forward just reverse
the machine needs to be serviced
May 19, 2012 | Singer 7422
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Sewing machine wont stitch in reverse, needle hitting bobbin feed.
since the needle is hitting the bobbin feed it has to be replaced, if the machine continues to hit the bobbin feed the most likely the machine is out of time & has to be retimed at a sewing machine repair shop
they would also be able to see why the machine won't stitch in reverse
Mar 31, 2012 | Brother XR-65t Mechanical Sewing Machine
Won't operate. Won't go forward or in reverse, happened all of the sudden. Hand crank fine, but the whirring sound comes from that area.
it's possible that something in the machine has come loose or broken
it would have to be serviced at a sewing machine shop
Sep 23, 2011 | Husqvarna Prelude 370 Sewing Machine
Sewing Machines Logo
79 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
