Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
My bosch dishwasher is stuck on the drain cycle
SOURCE: Bosch SHU9925UC Dishwasher Stuck in Initial Drain Cycle
OK Bosch Dw fans.........here is the fix if your SHX dishwasher is stuck on the drain cycle. This may save you a couple hundred bucks.......so listen up. There is a tendency for the very small float switch to STICK in the ON position, which will cause the drain motor to continuously run......and DISallow any other function to work. DISCONNECT POWER. Did I mention to disconnect power? Take off the front base cover....2 torx screws. Remove the other 2 torx screws in the metal clips that fasten the top of the DW to the underside of your countertop. NOW...carefull slide your DW out. You may have to disconnect your water and elec supply if you do not have enough slack to pull it out. Once the DW is out of the cabinet, remove the shiny metal cover on the LEFT side by removing a single torx screw. You will now see a small plastic assembly with a red plastic piece that moves up and down as it rides on a small red styrofoam float. This up and down movement engages a small white plastic switch visible with 3 wires coming out of it. You can carefully UNSNAP this switch out of its mount, and pull the 3 wire plug off of it. THere is a small square blue plastic tab that is supposed to easily slide in and out of the switch. If it is stuck IN, you can sometimes tap the switch and the blue tab will pop out, which is what it is supposed to do without tapping it. You can carefully with a knife blade separate the case on this switch and note the way it comes apart. Clean out any micro debris out of the small channels that the blue tab ride up and down in. Then set it in the channel while holding up the small switch tab that rides on it and see if it slides up and down without sticking! I like to take a piece of wax paper and rub in on the channel and blue tap to provide some lube for the switch to slide easily on. Now, put the switch back on and manually move the red plastic assembly up and down while you are watching the blue tab. The tab should ride up and down with the red assy. If not, buy a new switch. Google the # on the switch and order one. If the tab slides up and down, put things together in reverse order and give it a try. Hope it works for you. This should take you an hour give or take. Take the $200 you just saved and have a night out on me. ........so even though these German Appliances have a good name because of past reliability, the american tendency to value engineer them with plastic parts to reduce costs and increase profit.........just cost you an hour of your time. Will we ever learn.? ......if it ain't broke, value engineer it until it only lasts through the warranty period so you can then collect service and parts blood money from your fellow american.
Posted on Jan 11, 2009
  • 1462 Answers
SOURCE: bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Posted on Mar 20, 2007
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Bosch dishwasher stuck on drain cycle. Where would I find the float valve?
If the D/W tries to drain when the door is open, you will have water in the tray. open the service panel and check to see, drain, then run. Location on most Bosch D/W float is mounted on left chassis.
Sep 30, 2010 | Dishwashers
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Not drying and sanitize light is not coming on. Dishes are WET
is it draining ok? Are the cycles really long? if yes it might be a control module problem also found on other models.
Bosch Dishwasher Stuck on 2H
bosch dishwasher troubleshoot manual
I soldered mine. works.
keep us updated.
Nov 05, 2009 | Bosch Evolution 300 SHE33M05UC Stainless...
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
My bosch exxcel dishwasher will not drain after wash cycle
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch classixx slimline dishwasher not running through cycle
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
145 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
