Leak in condensation line of my carrier weathermaker 9200 furnace, water on floor
Leak in condensation line i think, water on floor
SOURCE: carrier furnace weathermaker 8000
I think the running on power up is just a test mode for a service person.
Posted on Nov 25, 2007
hotuna
  • 288 Answers
SOURCE: Carrier weathermaker sx 58 furnace
This sounds like a thermal disc or the heat anticipator on the thermostat is not set right. What was the $500 spent on?
Posted on Dec 19, 2007
  • 86 Answers
SOURCE: Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Posted on Mar 28, 2008
  • 14 Answers
SOURCE: furnace ices up,lines ice up,water condensation leaking in to duct work
1.check filter if really dirty change
2. check Refrigerant if low get charged by a tech
3. check the evaporator coil if dirty clean
Posted on Oct 16, 2008
  • 182 Answers
SOURCE: Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Posted on Oct 18, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Does my furnace require outside air?
I'm surprised the building inspector allowed the condensing furnace you described draw combustion air from the garage !! I'm not familiar with any manufacturer that recommends that as normal practice. Virtuall ALL two pipe condensing furnaces require both pvc pipes to be terminated OUTSIDE the structure with specific heights and distances apart. There is also a limit to the length of both the flu and the combustion air piping and each 90 degree pvc elbow adds the resistance equivalant of roughly 10' of straight pipe. If re-routing is required, you have to bear in mind the direction of 'fall' in the piping usually goes back towards the furnace and remember two 45's may give you a greater variance of change in the piping and still be equal to the equivalant of one 90.
Personally, I would never suggest terminating the fresh air (combustion air) intake between floors of a structure.
Jan 02, 2015 | Carrier Heating & Cooling
What do I do if red LED light stays on and my furnace (Carrier WeatherMaker 9200), does not start.
turn power off for 5 min to reset and check thermostat wiring the red wire should be connecting to the white try a jumper at the furnace
Sep 12, 2014 | Heating & Cooling
I have a carrier weathermaker 9200 - Water is leaking from under the furnace. I have checked the humidifier and in the furnace itself and cant find where the water is coming from. The furnace runs and...
Chances are it's from the condesate tubes or collector box. If not, you may have a cracked A/C drain pan- lots of installers over tighten the male adapter into them and cause cracks. next check to see if they installed all the condensate plugs at install, some installers don't- read the manual in the "how to set up the condesate" section and trace EVERY tube to make sure they are routed correctly and not cracked/ cut/ nicked. Most furnaces are multi-position now and some installers don't move every tube nessessary... Hope this helps, if not, post a close-up pic, and I'll pinpoint the bad spot for you...
Feb 22, 2013 | Carrier Humidifiers
Carrier weathermaker 9200 furnace air filter placement
air filter for your model can be found on amazon, click here and take a look: 20x25x5 Electrostatic Washable Furnace and Ac Filter 19 3 4 24 3 8 4 3 8. I hope this was helpful. Cheers
Feb 17, 2013 | Heating & Cooling
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38TZA036320 evaporator coil
Hello, sounds like a blocked drain line or cracked condensate pan. Try cleaning the drain line first with a wet/dry vac at the outlet of the 3/4 inch pvc line, if this does not help you will need to have the drain pan repaired or replaced.
Jul 04, 2012 | Heating & Cooling
Heating & Cooling Logo
255 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
