Question about Dryers
Beko condenser dryer making banging noise
Just started tonight. Tumble dryer making banging noise. Seems to be coming from the back. Any ideas on prob and how to fix?
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
hards327
  • 30 Answers
SOURCE: Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
Posted on Mar 17, 2008
SOURCE: Beko tumble dryer not drying.
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Posted on Aug 20, 2008
hunter19_46m
  • 7482 Answers
SOURCE: DRUM NOT TURNING ON BEKO TUMBLE DRYER. JUST OUT OF
Check your drum belt, sometimes this belt is broken or slipped off the motor pulley or idler arm pulley.
Also could be a faulty motor..
Another thing to try is to turn the drum by reaching inside of the drum and turning it by hand 1/4-1/2 turn with the dryer off. Then turn the dryer on again and see if it works.
Motors will sometimes get a dead zone in them and this help move it from the dead zone.
Posted on Sep 26, 2009
SOURCE: White knight tumble dryer making
I have this banging problem, it sounds like a plastic ball rolling about inside it
Posted on Dec 02, 2009
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
    check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
    Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
    Tumble dryer drum making a noise spinning
    hi take top off hold back of drum see if u can pull it up if you can feel play its more than liklely the bearing wot dryer is it
    Feb 13, 2014 | Beko Dryers
    My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
    Looks daunting to start with but just done mine,
    remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
    Feb 07, 2011 | Dryers
    I need to clean my filter on my beko tumble dryer!
    I usually just stick the shower on it to clean out all the bits of fluff that gets gathered in there, but remember to give the inside of that hatch u brought it out of with some kitchen towel before u put the condenser filter back in.
    Feb 23, 2010 | Dryers
    CREDA TCR2 TUMBLE DRYER
    put it in the bin
    Sep 12, 2008 | Dryers
    White knight tumble dryer (condensing) - burning plastic smell and machine seems really hot
    I have a whikpool condenser dryer that seems to work but has all the lights come on and a buzzing noise,any ideas to what it could be please? I have clearned all the filters etc
    Apr 19, 2008 | Dryers
    Dryers Logo
    108 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
