Question about Mitsubishi WD-60737 TV
White spots on wd-60737 screen
Cleaned lamp but spots still there
3 Suggested Answers
Mas Baz
  • 177 Answers
SOURCE: bright white spots on mitsubishi wd-73833 I just
Bright white spots on mitsubishi wd-73833 because DMD.
below is example for worst bright dots. If your case like pic below, change DMD.
Posted on Mar 24, 2011
SD Tech
  • 14553 Answers
SOURCE: White spots on screen Need DMD
This is something of an urban myth....The "DMD chip" is actually the LCD display IC for the set; yes I have seen some listed on EBAY---still a myth----they are replaced (when a light engine is rebuilt in a space age lab or environment) under exacting conditions----if positioned a micron off in any direction picture will be tilted in some way---this is also not like changing spark plugs in a car, if you have a optical engine issue like spots etc, either get a rebuilt engine from Mitsubishi or buy a new set.
They usually require some parts for old engine (mounting brackets etc) be installed on new or rebuilt engine.
I did see the "chip" for another model listed on ebay today.(100.00 PLUS)
I understand the engine is expensive, I replaced a lot of them when the sets were in warranty---more Mitsubishi than any other brand with Samsung a distant second.
I am sure Mitsubishi does not offer the part for sale--they want to sell a tested rebuilt engine only.
I wish you luck but have little hope you will find a "part" other than the whole engine.
SD TECH
Posted on May 14, 2011
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
Fan broken mitsubishi wd 60737 want to repair replace
Fan should be easy to replace try Encompass Parts Look on their website or try Mats Electronics for replacement fan.
Oct 08, 2012 | Mitsubishi WD-60737 TV
What is an optical block
the optical block is an integral part of the light engine which is the large black plastic unit that the lamp shines into.
Feb 24, 2012 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi DLP - WD-60737 - 1 year old I have sound but no picture. The lamp is not lighting up. I have already replaced the lamp. After I replaced it, the set worked fine for a couple of hours, but is...
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Mar 03, 2011 | Mitsubishi WD-60737 60 in. HDTV
White dots on my tv screen
this problem is coming from your DMD board it looks like some LCD chips are getting stuck in the on or off position you need to replace the light engine system to fix this problem check this link out
Please rate this solution as I do this for free!!!!
http://forums.cnet.com/5208-7596_102-0.html?threadID=257865&tag=forum-w;forums06
Sep 20, 2010 | Mitsubishi WD-73733 73" HDTV
Mitsubishi WD-60737 will shut off on its own while running on it's own surge protector and it's not overheating
These units had problems with capacitors in the power supply and main boards. Unless you like really hard CHINESE PUZZLES you are best to leave this to a pro.
Oct 12, 2009 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi wd-73727 have new lamp bulb;did not
Your Light Engine needs replaced. Usually around $600.00-$850.00
Jul 11, 2009 | Televison & Video
Mitsubishi WD-60737 TV Logo
432 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
