Hard drive refused to power on. When i plug the adaptor the light on the adaptor will blinking continously but no power on the External hard drive
  • ikoetteh Oct 24, 2008
    The Hdd is an External one....Its the Iomega Silver desktop External Hard Drive. Not in a PC. I have even bought a new Power pack. But same problem. Light comes on the Adapter but when u plug it to the External Hard drive..The lights starts blinking and wont power on the Disk
  • 59 Answers
Sounds like the drive has locked up the adapter is powering it but hdd can not turn try removing the hdd and replacing it with anouther.
Posted on Oct 24, 2008
When i power on my pc moniter not started hard disk light not blinking..
Are you powering on your computer and your monitor...
If your computer appears to boot, but nothing on your monitor...
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
If your computer won't boot...
The hard drive, motherboard, or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore or Reload on the computer, and if that works, copy your personal files back to your newly restored computer. Good luck.
Aug 05, 2014 | Computers & Internet
How to remove hard drive
you shouldopen theside cover panel,then remove the sres at side of the hard drves ulnplug iys connection,to convert it to external you need adaptor forconnection.whetheri itside or sata connector
Feb 06, 2014 | HP Pavilion Media Center M1070n...
E-Macine T1840
Emachines are known to have this problem. You are right... it probably IS the motherboard. As cheap as new computers are, I doubt that buying a replacement MB would be a wise option. A quick check on the internet shows they run at least $175... I saw an Office Depot/WalMart ad for $249 for a NEW system with Windows 7 and WAY MORE speed than you have now. Pull your hard drive, put it in an external case and transfer all your files to your new computer. Games, etc.. will have to be installed individually though.
Good Luck.
Dec 07, 2009 | Computers & Internet
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Aug 11, 2009 | Dell Dimension 2400 PC Desktop
Hooking up USB adaptor to internal hard drive on desktop
clsoe the cover.
look outside of the box. look at the rear of the machine. there should be 2 USB slots. there is none in the front of the machine.
The USB driver may not be correct, since it is PIII machine. go to HP.com and download the USB driver for the machine.
Mar 04, 2009 | Compaq Presario 5000 PC Desktop
Seagate 500 gig external hard drive problem
Your computer must have a firewire connection.
Jan 11, 2009 | Computers & Internet
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
