Question about Estate TGDS740JQ Gas Dryer
Eastate gas dryer 4-5 years old.
My gas dryer will start up but then goes out and runs and runs ,the timer wont run,if i let it sit for a while it will start up again but does the same thing,,,help
Dryer runs and runs timer is not working and it is not heating.
Posted on Nov 11, 2009
    Genius:
  • 1,028 Answers
If burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Posted on Oct 25, 2008
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Dryer not blowing hot air- timer not working
im assuming your on the automatic cycle. on this cycle the timer will not advance without heat. check you house circuit breaker/fuse. if one goes the unit will run but will not heat.
Feb 08, 2010 | Dryers
My 1998 contour svt has been sitting for two years, trying to start car, it wont..is the gas bad in the tank
If it's been sitting for that long, yes the gas goes bad. Drain the tank, fuel lines and even the spark plugs becuase the old gas will foul them too.
Check air filter for free air flow and possible critters living in the intake... two years is quite a while for a car to sit... Also after it's running have your oil and filter changed as well.
Nov 25, 2009 | 1998 Ford Contour
Whirlpool Gas Dryer LGR7646JQ1 Auto Setting Does Not work
I am thinking the timer has gone bad, They tend to work in some spots, and not others , when they fail. If you can put the dryer in Auto mode, then nudge the timer until you hear the burner light, see if it continues from there. If it does, chances are pretty good it's the timer.
Jan 27, 2009 | Whirlpool LGR7646E Dryer
WHIRLPOOL GAS DRYER MODEL LGQ9030PQ1 DRYER RUNS BUT NO HEAT
I would be suspect of the timer. Same thing happened to mine.
Rotate the timer manually a few degrees and see if the dryer operates properly. If so, replace the timer, a simple thing to do. Cost is about $75.00 and available from SearsPartsDirect.
Reply your findings and I will help you more.
Jan 23, 2009 | Whirlpool Dryers
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Estate TGDS740JQ Gas Dryer Logo
149 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
