Question about Canon PIXMA IP5200 InkJet Photo Printer
Printer won't print
The orange light is flashing and there is no paper jamming, what else can it be and how can i rectify the problem
    Guru:
  • Canon Expert
  • 183 Answers
Dear amcnabb,
How many times it's blinking? If it related to paper jam problem means there is problem with sheet feeder unit or paper sensor. Please check below link for detail.
Regards,
Source:
Canon Inkjet Printer Forum
Posted on Nov 22, 2008
The orange light flashes three times and it cant print and there's no paper jam
Did you remember to open the door for the paper to exit? Otherwise, if there's no paper jam check the paper path for debris; the sensor(s) might be gunked up.
Mar 03, 2015 | Canon Office Equipment & Supplies
Orange light flashing - won't print
have you got a reset button on your printer if so try pressing it down and holding for a few seconds put some paper in and try again
Mar 25, 2010 | HP LaserJet 1100 Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Feb 21, 2009 | Lexmark X2600 InkJet Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
Canon PIXMA IP5200 InkJet Photo Printer Logo
154 people viewed this question
old marine
old marine
