Question about Sony KDL40EX600 TV
Five blinking red lights on my sony bravia kdl 40ex600
Power button on / no picture / no sound /goes to series of five red light blinks then pause (no blink) the five red light blinks
redhead7377
  • 51 Answers
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Posted on Sep 09, 2008
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
rustym62
  • 201 Answers
SOURCE: Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Posted on Apr 27, 2009
  • 3 Answers
SOURCE: TV Goes to Stand-by mode
I don't have a solution, but I have the exact same problem
Posted on Sep 08, 2009
  • 8457 Answers
SOURCE: Our Sony Bravia Model KDL-32XBR6 wont open. The
Know how to solders?Power supply board have dead capacitors.Take the tv aparts,look for Capacitors that puff up or burst open.Replaced these capacitors well get ur power back.Or buy and replaced the whole
refurbish power board at Shopjimmy.com,Ebay.com.
Posted on Jan 23, 2010
What does " main board overheating" mean in Sony Bravia LCD? is it fixable or need to be replaced
On power boards if its overheating could be dry joints, look at solder joints for cracks round the joint or darker places on board.
Mar 02, 2016 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
Sony Bravia KDL 32BX300 Error codes
Five blinks denotes an IRK error. To detect damaged components and to troubleshoot this error, you must have sound in electronics.
May 21, 2013 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony Bravia KDL-46V3000 turns off with blinking front light.
Sounds like the power supply may be failing. Count the beeps next time, that will give you the error code.
Jun 18, 2017 | Sony BRAVIA KDL-46V3000 Television
14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Mar 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony KDL40EX600 TV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
