Question about Compaq Pentium II , 266 MHz Processor
HOW TO FIX PROCESSOR
Sir, i wanted to change my compacq pricessor, 266MHz to 440MHz, how can i be able to do the job successfully, please, tell me. Secondly, how can i be able to remove the first processor from my system without damaging it. please, state the step to follow. please, help me out. bye for now, hope to see your reply. Thanks.
  • chuks nduka Aug 11, 2006
    i need your reply immediately.
    thanks for ur anticipation.
By now you most likly found out it's more or less a plug out and back in, release the lock on each side of the processor lift up to remove and push back down to install.
Posted on Oct 05, 2006
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
Had this system for awhile but never had any problems. Todays internet media etc. are getting to be too demanding for the athalon processor that came bundled with this MB. What is the strongest/fastest...
http://www.xiew.com/product-detail/msi/kt4v-l/
A) Processor Socket:
Socket A (Also known as Socket 462)
B) Motherboard Chipset:
VIA KT400A
VIA KT400A Northbridge chip,
VIA VT8235 Southbridge chip
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
[ Info reading across from the subheading KT400A, shows one, of two newer Southbridge chipsets could have been used.
The VT8237, or the VT8251.
Neither one was apparently used, or the website's info is mistaken ]
The Northbridge chip (VIA KT400A) will support;
A) Processors with no more than a 266MegaHertz Front Side Bus. (266MHz FSB)
It will support Processors with either a 200MHz FSB, or 266MHz FSB.
(AMD processors are 'double-pumped'. The 100MHz, and 133MHz FSB support shown, is 'double-pumped' to 200MHz, and 266MHz )
AMD Athlon XP with a 266MHz FSB, that fits in a Socket A processor socket, IMHO is the best.
[ To digress;
Chip and Chipset are slang terms to represent I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip is so aptly named, for one, because it sits on the North side of the motherboard. Looking at the motherboard as a map, the Processor sits due 'North'.
The white long PCI slots sit due 'South'.
{In the illustration of the MSI KT4V motherboard above in FixYa, turn the motherboard to the Left }
The Northbridge chip and the Southbridge chip is the Motherboard Chipset.
The Northbridge chip handles the faster capabilities of the computer.
The Southbridge chip handles the slower capabilities of the computer.
The Northbridge chip handles the Processor, Ram Memory, and High-speed graphics.
A graphics card inserted into a PCI slot is Not high-speed graphics.
Neither is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics. ON the motherBOARD.
The GPU is soldered to the motherboard, not on a removable graphics card}
Motherboard Diagram, (That is for the technology used for the MSI KT4V motherboard.
Does not apply to motherboards supporting the Intel Core i3, i5, i7, and i9 processors),
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Northbridge chip is the motherboard chip to be concerned with, when deciding what Processors the motherboard will support.
Finding an AMD Athlon XP that fits in a Socket A processor socket, and has a maximum FSB of 266MegaHertz, is a wee tough.
In my recent search I have seen some advertised on Ebay. DO NOT know anything about them.
Here is an AMD Athlon MP 2000+,
http://www.weirdstuff.com/cgi-bin/item/13161
,that operates at a maximum of 1.67GigaHertz, and uses a 266MHz FSB.
Not advertising for the above website either, but I have dealt with them to great satisfaction.
For additional questions please post in a Comment,
Regards,
joecoolvette
Jul 14, 2011 | MSI KT4V (MS-6712) Motherboard
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
Hp pavilion dv2000 fan continually cycles on and
your processor that is over heating so you want hitsink craen on the pricessor for cooling
Apr 13, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Swapped in 2 ddr 512 266mhz sticks for, 2 sdram 512 133mhz sticks. no boot, only beeps, neither sticks will work in either slots. cpu has a athlon xp 2000 133mhz processor, is this the problem? Do I need a...
Your motherboard works only with 100 or 133 MHz memory modules.
You hear the beeps because the motherboard is telling you that the memory is not compatible with the board.
The processor is not the problem.
Don't forget to rate this answer if it helps
Dec 05, 2009 | EliteGroup K7VMM Motherboard
Dear sir/madam i want to
go to proprofs.com or comptia.com
Aug 31, 2009 | Acer Computers & Internet
Processor compatability
Processors have a matched frequency rating with the motherboard and memory. So, when replacing or upgrading the processor, the new processor will need to have the same frequency as the old one. If the processors use the same type of memory, ie... PC2100, then ther are most likely compatable, and the use of a processor that was made for or from the same make of laptop is always a good idea. Some processors are designed specifically for use in certain manufacturer's system configurations. For example; say you have a Dell Latitude C840 with a 1.8ghz processor and you want to upgrade to a 2.2ghz processor from a Dell Inpiron 8600, this will work. Both of these machines use the PC2100 memory and have a matched frequency rating of 266mhz, and the processors are made for use in Dell machines. If you would like to tell me exactly what you're wanting to do, maybe I can recomend a processor for you. Let me know.
Jul 22, 2008 | AMD Computers & Internet
Change of processor
yes its possible to change the processor but yes you need to put the 2gb ram because the new come processor support min 2gb ram only.but it support the 1gb ram also.
Jun 04, 2008 | HP Compaq Presario V2000 Notebook
Upgrading/Identifying Pcb Inputs
Your mobo will take a pentium 4 socket 478 processor, what Ghz you want it upto you, i think they went upto 2.8Ghz but i could be wrong. This is an old socket type board so you may be better upgrading it or try the internet for a supplier. The max amount of memory you can use is 2GB of DDR memory 266MHZ or commonly known as PC2100.
Feb 11, 2007 | EliteGroup P4VMM2 Motherboard
Compaq Pentium II , 266 MHz Processor Logo
1,109 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
