Question about Philips 55P8241 55" Rear Projection Television
Fuzzy picture The picture is a little blurry/fuzzy. Also i cannot seem to get the color scheme quite right. Any ideas?
  • MaveGirl May 11, 2010
    I HAD the same problem, then I replaced the coolant just like the manual said, but now the screen is clear but it's also just black with a red, blue, and green stripe across it. No picture, no sound, can't access menu, etc.
    Did I do something wrong?
  • Philips Master
  • 3,459 Answers
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become  cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Dec 22, 2008
  • Edward
    Edward May 22, 2009
    Check your cables!
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Fuzzy or Blurry Pictures
Please see the following comment:
Dec 29, 2009 | Canon PowerShot A95 Digital Camera
Fuzzy picturethe
If the colors appear to be aligned and the only isue is focus, than you can adjust the focus on the flyback transformer. Carefully remove the rear cover and locate the flyback transformer (part with large red wire coming out the top). There should be 2 controls/adjustment points on it. One is for screen and the other for focus. Try adjusting the focus using a mirror to see the front of the set. You should adjust the control back and forth a ferw times to "loosen" it up a bit before settling down to the focus point.
Update this with the results.
Dan
Nov 30, 2009 | Zenith R57W46 57" Rear Projection...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
BLURRY OR FUZZY LENS
Perhaps you have had the camera in a very humid environment and now there is condensation inside? Perhaps try putting it somewhere warm and dry (not hot) for several days. Switch it on and off (and zoom in and out a bit) a few times during this period to change the air inside the lens. This will help expel the moisture.
I assume that it isn't just finger marks on the front of the lense? If it is, you can use a cleaning cloth (for eye glasses or from a camera shop) to clean it.
Jul 20, 2008 | Samsung Digimax A402 Digital Camera
Philips 55P8241 55" Rear Projection Television Logo
212 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
