Question about Kohler Plumbing
Remove bathroom sink flange - Kohler Plumbing
    Guru:
  • 15 Answers
Turn off the water valves at the back of the sink and place a bucket underneath the drain to catch any water that may run out.
2 Loosen the nuts that hold together the drain tailpiece and the P-trap with a wrench. Disconnect the the two pieces.
3 Unscrew the drain tailpiece from the drain flange. Depending on how the drain flange is held in place, you may need to hold it down firmly as you twist the tailpiece below. Remove the tailpiece and set it aside.
4 Remove the old drain flange. It may come straight out after the tailpiece is removed, or it may be held in place with putty or silicone. If it is held in place tightly, grasp the edge with a pair of pliers and pull until it comes free.
5 Wipe down the sink area that was underneath the old flange. If the metal was discoloring or rusting, clean the porcelain well and dry it to keep the new flange clean.
6 Apply a thin bead of silicone caulk to the underside of the new flange. Push the new flange into the drain hole in the sink.
7 Push the drain tailpiece back up into the sink's drain from below and screw it into the flange tightly. Use a wrench to tighten it up securely.
8 Reconnect the P-trap to the tailpiece and tighten the nuts that hold it in place. Turn on the water supply to the sink and run water through the pipes to ensure everything is securely fastened.
Things You Will Need
  • Bucket
  • Pliers
  • Adjustable wrench
  • Silicone caulk
Duplex Steel flanges Duplex Stainless Steel Flanges Manufacturers Suppliers Instinox
Posted on May 30, 2016
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: bathroom sink pipes came apart and flooded our
Hi, W/D here.
Almost always, the shutoff valves are at the wall where water is supplied to the faucet. If the problem is with the drain piping, and the faucet valves don't leak, you don't have to shut off the water. Simply replace the drain piping and tighten it up. If you need any repair parts, you can get them from any hardware store. Please repost if there is anything else that I can help you with.
Good luck, and best regards,
--W/D--
Posted on Aug 13, 2009
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
The strainer/stopper is stuck in the kitchen sink the sink has a disposal unit attached. How do I remove it from the top
We just experienced the problem describe in this question. A dinner guest pushed the strainer stopper past the Blanco flange over the disposer and the stopper could not be removed by pulling straight up. The Blanco flange is difficult to remove so we knew that removing the flange would be a last ditch effort. I tried using several tools trying to deform the stopper enough to lift past the lower part of the flange but without success. While I was on the internet looking for a solution, my wife found the obvious answer. She pushed the stopper down into the disposer, rotated it 90 degrees. She then aligned the edges of the stopper with two of the small indents in the lower part of the flange. The stopper was then pulled up past the flange where only two points on the circumference of the stopper contacted the flange.
Kudos to her for this simple solution.
Sep 24, 2012 | Blanco Sink Waste Strainer / Stopper...
How do I replace the flange on the side sprayer? The sprayer and hose are intact but the part of the flange that screws broke and has to be replaced. Quesiton is where do I disconnect the hose so I can...
The hose that goes to the Sprayer has to be disconnected under the sink at the main connection there, then it can be pulled up and out of the top of sink. the you can unscrew the nut under the sink on the flange and remove and replace.
Aug 28, 2011 | Price Pfister Marielle Kitchen Faucet with...
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
When I turn on the cold or hot water sink faucet water leaks out from the top of the cold water faucet . I took the outer casking off and can not figure how to remove the stem. I removed the ring but...
if you have the ring removed, screw the handle back on and pull up on it,, your leak is probably due to a worn , torn , "O" ring,, and Moen parts are found at most hardware stores ,, ( including Home depot , and Lowes) On Moen faucets , Look for the dent in the flange that squares off,, where that square is on the ring, is where the retainer ring is that holds the faucet in place ..its a "C" clip with a head on it, remove this ring and the assembly should come out , be sure and use plumbers grease when replacing the O rings,, they last much longer that way
May 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
LOW WATER PRESSURE IN downstairs bathroom sink
If it has a filter on the tip remove it and retry.
Feb 25, 2010 | Delta Plumbing
I need to remove the popup from the bathroom sink drain to clean it. It has a plastic looking "wire" going to the tailpipe under the sink and it looks as if I'll have to take the whole thing apart ot do...
unscrew the pop up lever from the sink drain, under the sink, and remove the popup, when you remove it make sure you remember to put it back the same way and tighten it good or it will leak
good luck
Jan 16, 2010 | Home
Etching on Pegasus sinks from standing water on clear sink
You can get an acrylic sealant to put around the drain. It will fill the void where the flange on the drain hole and the sink meet. Possibly an epoxy would work but some tend to yellow with age.
Mar 16, 2009 | Home
Remove the base of a pedestal sink.
There are two bolts on either side of the sink. Remove them and lift the sink off of the base. Sometimes, depending on who installed it, you can slide the base out without removing the sink. Hope this helps.
Mar 14, 2009 | Home
Plumbing Logo
299 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
