Question about Water Heaters
Lochinvar water heater trips breaker
As soon as it turns on maybe a second or two then trips breaker
  • 398 Answers
SOURCE: My Titan N180 water heater keeps tripping the breakers
replace the breaker.
Posted on Feb 27, 2009
  • 408 Answers
SOURCE: THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Posted on Mar 04, 2009
  • 234 Answers
SOURCE: Water heater trip circuit breaker
I would say you have a bad element in the bottom.If the water is cold and heat until the top thermostat reach it tempture,then switch the bottom element and then the breaker trip.So replace the bottom element.
Posted on Mar 15, 2009
  • 234 Answers
SOURCE: My Titan N180 tankless water heater keeps tripping
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
Posted on Mar 20, 2009
  • 65 Answers
SOURCE: circuit breaker trips on electric hot water heater circuit
Check the voltage at the water heater. Sounds like the element is burnt out and is tripping the breaker.
If it is more then 5 years old I would check.install a new heating element.
Posted on Mar 27, 2009
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Oct 22, 2012 | Water Heaters
Water got extremely hot and then tripped a breaker. now if i reset the breaker and turn on the hot water switch on the wall, all is good. but when i turn the switch on the hot water heater itself it trips...
Sounds like you have a short in wiring for 120VAC system of water heater. Shut breaker at panel off, and remove cover on back of water heater to look for any burnt wiring at connections such as switch, or thermostat/eco assembly.
Jun 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
