Question about Maytag Refrigerators
Pink liquid leaks from under fridge
From front right side
HVACRH20
  • 237 Answers
SOURCE: Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Posted on Nov 10, 2006
  • 833 Answers
SOURCE: pink fluid under refrigerator
Loklok...no, I don't think so. The only fluid in refrigerators is an oil which is sealed in the cooling system and we know you are cooling. Your fridge may need a full defrost. This occurs because you may have left items uncovered and the moisture condensed in the cooling coils. It could also be the result of improperly sealing doors caused by dirt/ bad gaskets or the like. Best thing to do: shut it off, open the doors and let it defrost fully for a day. Clean the condenser coils under the unit with a long brush. Dry out as best you can and restart. You'll likely be okay. Make sure your freezer side is at about 0-5 above...refrigerator side 35-45. Use a regular thermometer and leave the door closed for at least an hour. (Do these measurements a day after you've restarted.)
Posted on Jan 28, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire Model #FRS22WRC Side by Side leaking
Check the bottom of the freezer side is there a sheet of ice???
Posted on May 20, 2008
Bgillespie
  • 89 Answers
SOURCE: water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Posted on Dec 02, 2008
  • 531 Answers
SOURCE: side by side leaks out front door on freezer side
you may have defrost problem
Posted on Apr 07, 2009
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
I think my cooling unit is shot, but about the same time of my fridge going out I had what seemed like a water leak. It was in a closet no where near any water lines,but on the same side of the closet...
These RV fridges are filled with ammonia, sounds like your unit has a leak, You should remove your fridge and possibly get it repaired , refilled and tested, or find a used one, These units are a few $$$$.
Oct 12, 2010 | Dometic RM2652 Refrigerator
!998 Dodge Caravan is leaking a clear liquid left of battery.
antifreeze by the sound of it ,but it could be battery acid from a damaged battery casing
May 16, 2010 | 1998 Dodge Caravan
1998 Rav 4 is dripping pink fluid onto ground from back right corner. Wondering what needs to get fixed.
the only thing located in that area is the tranmission.if you want,jack the car up from that side,support it with a jack stand,then get under your car and check all trans hoses including the trans,for any leaks.if the liquid is pink in color,then it has to be transmission fluid that is leaking ok.good luck and take care, manny
Apr 21, 2010 | 2007 Toyota RAV4
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Rear fluid leaking in Suburban after backing into telephone pole
Yes, sorry, that's what I meant. When you have a rear heater system, they usually incorporate (use) another heater core, similar to one under dash for heat, in rear . I'm thinking you have Pink type antifreeze in your radiator & cooling system return bottle, and that's what feeds that heater core in rear as well as front, for heat. It's usually located behind the rear side panel in back of the Suburban.
Better check your coolant level in engine too, it is probably going down, as much as your leaking, and you don't want to cook the engine.
Apr 07, 2009 | 2003 Ford Crown Victoria
Leaking fridge ge
1) Check to make sure nothing has spilled in it. I had a bag of peas split open once and they were blocking some area and causing an airflow problem. I would then get Ice build up then it would thaw and spill on the floor.
2) I'm sure you have done thisw but make sure a water line does not have a split or pin hole.
Aug 09, 2008 | Refrigerators
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Leak water on floor once a month
This likely a defrost cycle issue. Your drain tube is likely clogged. Get under there and clean it, clean your condenser while you're at it. Cut down door openings, open liquid in the fridge.
Jan 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
679 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
