Question about Samsung SGH-a737 Cellular Phone
How to replace the LCD screen on the SGH-A737 samsung
How do I take the phone apart to replace the LCD screen on the slider phone
To remove the slider mechanism, take out the 4 visible screws first (under the battery cover). Then on the back of the phone at the bottom, remove the 2 little rubber circles with a tiny flat head screwdriver to reveal 2 more screws, take those out. Take out the 2 screws on either side of the flex cable that is coming out just below the battery compartment. Next is the part that took me hours to figure out. Beneath where the battery sits is a long oval shaped thing (=======) <- looks something like that (sorry I don't have pictures). This is actually a sticker. Peel this up and remove the 2 screws under it (keep the sticker intact becase you will need to replace it later). This will detach the slider from the phone. Make sure to gently disconnect the flex cable from the mainboard first.
From there you can see more screws that will help you take apart the sliding part of the phone to access the lcd screen if you need to replace it (which is what I was doing). It's pretty easy from there to get everything else apart. Make sure when you disconnect the cables from the back of the LCD screen, that you flip up the little release tabs on the connectors first.
Posted on Jul 28, 2009
    Brigadier General:
  • 7,752 Answers
It is best to take the phone to a professional mobile service center and have them replaced the LCD for you.
Posted on Nov 02, 2008
2 Suggested Answers
samrat_babui
  • 296 Answers
SOURCE: How to replace lcd screen on Samsung SGH A737
hi
If you just want to replace the plastic cover on the phone which is on top of the lcd screen then get a small screw driver and lift off the plastic from the top where the ear piece is situated. The plastic cover will lift of quite easily and you then just replace the clear cover with a new one. Make sure that you are in a dust free area so that no dust is trapped between the plastic screen and the lcd screen. You should be able to buy the plastic screen covers from ebay for under £5
OR
the lcd screen? hmm is it blank or cracked ... probably I would chuck it for the new cells are free with a contract, but if you have to ...
contact the manufacturer and order and a screen and get a set of tiny screw drivers to open it .. some are tricky and you need to figure out where they hide the screws .
REGARDS
Posted on May 27, 2009
My daughter has a Samsung SGH-A737 slider phone. The problem started out being intermittent but got worse over time. The speaker would go out and she couldn't hear anything when she was on a call. She...
I have samsung e250 with same problem.
sound plays with static, then disappears.
I try to shake the slider or press it hard, and sound comes back.
seems to be a bad connection to the speaker, or maybe a dry solder joint on one of the ICs.
Oct 21, 2010 | Samsung Car Charger for Fin, SGH-A117,...
How to remove samsung a737 slider?
After spending several hours and a trip to Lowe's for the right screw driver n needed to take the phone apart. I still couldn't figure out how to remove the lcd screen. Therefore, I decided to buy the lcd screen online and I will take my phone to a professional for repair.
Aug 30, 2009 | Samsung SGH-a737 Cellular Phone
Switch Samsung SGH-a737 Slider to PC mode without using a screen
dont worry n dont do any thing silly its just a connecter problem it will fix in just 250 bugs
Jul 27, 2009 | Cell Phones
Samsung sgh-a737
You need to place the phone in a bag of rice for 24 hours. This usually works to get all the moisture out of the phone. I hope this trick helps.
Jun 23, 2009 | Samsung SGH-a737 Cellular Phone
How to remove the slider portion of a samsung model sgh-A737
I have a U600 phone, but maybe this is a similar construction. I was able to detach the slider by removing 6 tiny screws hidden behind the sticker which you can see when you take out the battery.
Jun 10, 2009 | Samsung SGH-a737 Cellular Phone
Trying to remove the slider on SGH-A737
To remove the slider mechanism, take out the 4 visible screws first (under the battery cover). Then on the back of the phone at the bottom, remove the 2 little rubber circles with a tiny flat head screwdriver to reveal 2 more screws, take those out. Take out the 2 screws on either side of the flex cable that is coming out just below the battery compartment. Next is the part that took me hours to figure out. L Beneath where the battery sits is a long oval shaped thing (=======) <- looks something like that (sorry I don't have pictures). This is actually a sticker. Peel this up and remove the 2 screws under it (keep the sticker intact becase you will need to replace it later). This will detach the slider from the phone. Make sure to gently disconnect the flex cable from the mainboard first.
Jun 05, 2009 | Samsung SGH-a737 Cellular Phone
hi
OR
REGARDS
May 27, 2009 | Samsung SGH-a737 Cellular Phone
I need to replace lcd display on the samsung sgh-a737 phone.
I had the same problem with my son's phone. Purchased an LCD from Y'ALL online. Lot's of aggravation/frustration but I was able to replace it with much technical help from two of my co-workers. You need a lot of patience but it can be done. Basically you have to dis-assemble the entire phone including removing the slider. I took some digital photos along the way, however they are a bit blurry. I can do something up in powerpoint or adobe for instructions. But be aware.... even with this it is not an easy fix.
Mar 26, 2009 | Samsung SGH-a737 Cellular Phone
Changing the LCD screen on a Samsung A-737
I had to take my sons phone apart when it got wet. I believe the screen was held in with some type of double sided tape. But you have to take the phone completely apart to get to it. I took it apart about 6-8 months ago and it is still working.
Mar 10, 2009 | Samsung SGH-a737 Cellular Phone
Instructions on how to replace the slider part of the phone
1. take off the battery cover and take off the battery
2. take off the sticker hiding 2 screws that used to be behind the battery
3. unscrew every screw that you see on the back
4. take off the back
5. gently take off the chip. its safe unless your force it off
6. gently take off the slider part
7. unscrew the screws on the slider part
8. take off the 2 parts that are both beside each side of the LCD screen
9. now you can do anything you want
Oct 24, 2008 | Samsung SGH-a737 Cellular Phone
Samsung SGH-a737 Cellular Phone Logo
1,571 people viewed this question
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
